My N42 Flow figures at the moment
Dusty
So been working on porting n42 for my l28 build.  Valves are stock size rebello intake valve factory exhaust.  Test depression 28" water.  Not much material removed from runner mostly bowl, seat, and chamber work.  Was just wondering how these compare to anyone that feels like sharing.
Bore is 88.5mm.  Cr is intended to be around 10.5 but head is at welder getting chamber closed up wont really know where it will end up till after its straightened back out and milled flat.  Undecided on intended use either hot na or possibly turbo
