Sign in to follow this
turbogrill
Exhaust Manifold studs vs bolts?
Hi,
Does some heads use studs and some bolts for the exhaust and intake manifold?
On my old engine (N47/N47) I have two studs for the exhaust manifold and rest bolts. For the new engine I am building (F54/old N47) I have two bolts and rest studs.
I am confused....
Share this post
Link to post
The factory used a combination of both as Colten noted. On race cars I switched everything out to studs, as we often had the Intake manifolds off and on. Made the install faster, plus less danger of pulling a thread out of the aluminium. Even the thermostat upper housing had studs. This was after a certain Ham fisted friend/crew managed to over tighten and strip the threads out of the lower thermostat housing. Doh!!!
I worked at a Nissan dealership Parts Dept so had plenty of access to  high grade Nissan studs. In fact I always made sure that we had lots of the " special " hardware like half-shaft bolts and nuts.
It was funny, but the local Metro Vancouver Nissan dealers always had the best supply of high grade fasteners in stock .   A lot of the Parts and Service staff  Road Raced at WestWood.  Most of the shops used Bowman fasteners for their " Standard  Fastener"  shop supply.  I always made sure that the Road salesman always loaded us up on nothing less than the Metric equivalent of Grade 8 or better.
Share this post
Link to post
On 2/7/2018 at 9:59 AM, HuD 91gt said:
Studs are used for the exhaust manifold from the factory.  Unsure what factory used for the upper intake, but I do believe bolts were used.
Hmm....maybe the bolt was so rusted on the stud so I actually got the stud+bolt out.
Lucky you :)
 I am looking at getting Pallnet or Datsun Sprit kit, $40-$60 for some fasteners....
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
