Sounds like a bad starter motor.  I'd take it out, give it a couple of gentle whacks with a hammer and see if it spins when voltage is applied.  Rebuilt units are pretty cheap, last I checked.  Double-check me on this, but I think I once accidentally replaced my 240 starter with a 280 and it spun the engine with a lot more vigor than before, despite being cheaper.
Share this post
Link to post
Sounds like the starter is gone. As above, try a few gentle taps on the starter (don't want to break the permanent magnets), or try replacing it. Direct drive starters are $30 on rockauto, or you can spend a bit more and get a gear reduction starter for a 280zx (no real reason to). If you do get a replacement, be sure to get the one that matches your transmission (auto/manual are different)
Share this post
Link to post
Good on ya'.  A lot of folks will measure their voltage at the battery, but that doesn't necessarily mean your starter and/or distributor is getting that full voltage.  The electrical systems on these old cars suck.  Never miss an opportunity to clean your connections and grounds, and replace the old wiring with new, thicker-gauge wire.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
