Sign in to follow this
Zoomer
How to remove glass from 280z OEM door mirror?
I need to remove the glass from my '77 280z OEM door mounted side mirror without breaking it. Does anyone have a good method to remove the glass from the OEM door mirror housing?
Does anyone know if there is a source for the replacement mirror glass cut to shape for the '77 280Z?
Share this post
Link to post
Do you know how it is assembled?  Is the glass glued or double stick taped to a backing plate?  Once you remove the glass, is there access through the backing plate to the screws holding the mechanism with the gimbal in?  I can't see enough behind there to know how it is assembled.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
