Posted (edited)
LS engine potentially for sale soon.
MegaSquirt MS3pro plug and play LS wiring harness and ECU. SOLD
Hawks LS 240z 1-7/8" long tube headers.  SOLD
  • These are the best long tube headers available for the 240z LS combo.
  • Talked with hawks and had these the collectors angled to fit an auto trans! (will also fit manual). Likely the only long tube headers that'll fit an auto trans!
Holley ULTRA XP Carb, Intake and MSD ignition   $800  (total cost was $1400)
  • (bolted together, but never used)
  • Holley  ULTRA XP  750CFM    Jegs:  510-0-80803BKX
  • LSx carb'd intake + MSD ignition box   Jegs kit: 510-300-132K
  • dual feed fuel line
700r4 Transmission (Complete) $1200 ($2k invested -- I may keep this, trying to fit into next car)
  • Jegs Performance 700r4 Transmission   (works with LS)
  • high speed torque converter.
  • Flywheel
The 240z: $6,000 SOLD
Some Photos:
https://imgur.com/F0UYyJj <NEW 5/1 exterior
https://imgur.com/vCrYBpy <NEW 5/1 rear underside
https://imgur.com/iRfImPN  <NEW 5/1 front wheel
https://imgur.com/9vmuuca <NEW 5/1 rear wheel
https://imgur.com/J73BiMQ <NEW 5/1 hatch floor
https://imgur.com/7ifnO56 <NEW 5/1 hatch area/floor
https://imgur.com/rpiPVyM <NEW 5/1 hatch area
https://imgur.com/3B4Be8p <NEW 4/28 dash with speedhut speedo
https://imgur.com/HPFDhPv <NEW 5/1 dash area (mind the dust)
https://imgur.com/OLKoOXj  <NEW 5/1 suspension
https://imgur.com/JcdBphQ <engine bay photo
https://imgur.com/8gYOIWM <exterior
https://imgur.com/d3HMGvw <currently in the garage
https://imgur.com/EITVYbh <under side floor passenger
https://imgur.com/tFPdcCG <under side floor driver side
https://imgur.com/nxPbw8U <exterior with air dam up (this photo is older, but nothing has changed)
1971 Datsun 240z. INCLUDES THE FOLLOWING
Hoke Performance LS motor swap mount kit.  -- for auto or manual trans.
280zx brake booster
wilwood master cyl.
new classictube.com brake lines front to back
stainless braided fuel lines,
aeromotive regulator
Tanks Inc. poly fuel tank, and fuel pump,
Radiator:  champion 3 row + custom an fittings
deka etx20l battery with braille battery bracket
Speedhut GPS speedometer,  with high beam and turn signal markers (photo here)
speedhut tach and alternator gauge and gauge faces,
Spare dash harness included.
Marugen Shoukai Flares (best quality I could obtain)
Wheels: Rota RB-R 17x9" and 17x9.5" Hyper Black with Polished Lip.
Tires: Cooper RS3-S 245/17 and 275/40/17
I've cut out the rust and welded in new metal at doglegs, battery tray, and hatch/tail light area, it really just needs painted.
Engine bay painted in bmw deep sea blue.
Engine bay/triangulated strut bracing added from firewall to struts.
Spare tire well removed (for new fuel tank) and custom bead rolled sheetmetal replaced it.
triangular bracing at rear struts  bad dog frame rails (not installed)
Interior is currently stripped, but stored in garage. Most carpet was thrown out--Its cheap and easy to replace.xenon flex urethane air dam
camaro fender Vents behind rear tires:  (see bjhines car for reference)
hatch panel  z source Arizona
Edited by spitsnaugle
photos
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
