Cold air intake yes or no?
I had my N42 Head reworked - new cam grind, new springs and rockers and lashes, all from Rebello racking. It’s shaved 30k to increase compression. Also just bought new timing chain. Have new header and 2.5 exhaust from Mtrsprts. Stock PC, stock injectors, running stock AFM and intake. Will an air intake help boost hp or not?
Oh this is a 75 280z.
Your air intake is already a cold air intake if you're running the stock one.  If you want more induction noise and maybe less restriction then I guess you could replace the original air box with a cone filter, but realistically the change will be minimal since the stock position is already in front of the radiator in the coldest place you could put it.
  • Like 1
Yes it’s the stock one. Ok no change then ! Thx!
