Fenders
Aftermarket fenders are pretty much all from Tabco I think. I bought one from blackdragon when they were going out of business. Wish I'd bought both only because it was clean metal. That being said, they will most definitely not fit without some work. I spent a few hours trimming excess metal from the stamping and bending some parts to properly curve with the rest of the car. Bolts up front did not fit very well and required some serious pulling by the headlight to fit. Can't speak for how well the lower bolts into the rocker panel fit until I swap them onto my new shell. Last shell had replacement rockers which of course also require some work to fit.
yes, showcars has terrible rep, i found out first hand. and aftermaket sheet metal always seems thinner than OEM. my aftermarket fender will get waves in the top from people resting their hands on it. (i know, people shouldnt be leaning on my fender but it happens and my OEM fender handles it). if you can find a good used fender the metal will be thick and your fitment should be best compared to aftermarket. but if you cant then you do what you gotta do
