I recently fixed an engine oil leak that made a mess all around the underside of my 77 280z. After a few months of the leak stopping I noticed that my transmission is also leaking at the rear where it meets the the driveshaft. I also noticed it only leaks when I drive it.
Is this because the transmission might be overfilled? Or could it be a bad seal? If I have to remove the driveshaft, what's the best way to do it? I'll add some pics, you can see the oil drip and splatter all over the car. Thanks!
Edited by smsms
Could be, check it
Could be and it's easy enough to replace
You'll need to remove it if you have to replace the seal.  Just unbolt the drive shaft at the differential and pull it out of the transmission.  Be sure to grease the seal before you reinstall the drive shaft.
Thanks for the reply!
I think ill replace the seal anyways, then refill the transmission with new oil.
Is there a lubricant you can recommend for this?
