Wanted: R200 Finned Diff Cover
LLave
21 hours ago, jthom5147 said:
I have a short nose finned cover, if you’re interested.
the mustache bar bolts are spaced wider and the housing bolts are slightly larger but would bolt to a long nose case.
I have considered this rout. How far off are the mustache bar bolts?
Longnose R200 is 4.25" spacing, Shortnose is 4.75" spacing.
If you do get the finned cover you'll have to get a different transverse bar to connect the drop mounts for the rear suspension. The fins clash with that the stock piece and you have to raise it up.
Arizona Z car does it like this.
To get both the mustache bar and everything else it's about 550 bucks. Not super cheap, but it'll work, and it'll look fantastic! :)
  • 3 weeks later...
