82-83 Turbo ECU/ECM
rhettro74
16 hours ago, stprasinz said:
Why not upgrade to a z31 turbo ecu? Pretty straight forward...
easiest way,
ecu, harness, and afm
then it’s just a matter of some splicing of the wires. You get a majorly updated ecu then. Making you more power in stock form.
Are you selling a z31 setup?
That’s assuming you are already running the turbo distributor for 82-83.... I have one, or could I should say... 87 turboecu harness afm. 275or with a nistune ecu, harness and afm 550
ps you would need a cas wheel from a vg30e(t) also to put into the stock dizzy
if your not running the distributor, I have one for an 82-83 turbo, with an oil pump shaft for it, for another 200, and can include the cas wheel for a vg30...
Edited by stprasinz
  • 3 months later...
