R230 Axle assembly: a pictoral review
  • Please log in to reply
101 replies to this topic
#21 mas28O
mas28O
    Member
  • Members
  • PipPipPipPipPip
  • 621 posts
  • LocationDanville,CA
Posted 06 February 2004 - 06:15 PM
Tim what are you doing about the inner stops? I am using some on my R230. I am going to help khashabi1 (JOHN) tonight put his new R230 axle's together.
1972 240z
LS1 swap now 1999 LS1/4l60e SOLD
1993 RX7 LS2/t56 550rwhp 10.5@136mph NA texas mile 196MPH
Now turbo LS9e allowed maximum of 500 x 100 pixels.[/u][/i]"
#22 Tim240z
Tim240z
    Administrator
  • Members
  • PipPipPipPipPipPipPipPip
  • 5161 posts
  • LocationNear: Los Angeles, California, United States
Posted 06 February 2004 - 07:20 PM
I haven't done anything yet, but I plan to just squeeze some silicone in there and let it set up.
Tim
#23 Scottie-GNZ
Scottie-GNZ
    HybridZ Supporter
  • Donating Members
  • 2608 posts
  • LocationOrlando, FL
Posted 07 February 2004 - 05:43 AM
Tim,
NICE JOB!!
#24 Z-Dreamer
Z-Dreamer
    Member
  • Members
  • PipPipPipPipPip
  • 558 posts
  • LocationSacramento, CA
Posted 07 February 2004 - 08:38 PM
Ok, so are the stub axles the only weak link left?
Is the R230 available in 3.70 to 4.10 gear range?
Mark
" Speed costs, so how fast do you want to go? "
#25 Tim240z
Tim240z
    Administrator
  • Members
  • 5161 posts
Posted 07 February 2004 - 08:39 PM
3.54 from the Q45, and from what others have posted, 4.11 from Z-TT
#26 Guest_the_dj_*
Guest_the_dj_*
  • Guests
Posted 08 February 2004 - 10:26 PM
It's a 4.08, but I don't think anyone can tell the difference when driving ;)
#27 Tim240z
Tim240z
    Administrator
  • Members
  • 5161 posts
Posted 09 February 2004 - 11:56 AM
Just as a matter of FYI...the two complete axles weighed 37lbs for shipping purposes. Take maybe 1.5 to 2 lbs off for the packaging materials (box and extra cardboard for packaging integrity).
Tim
#28 john kosmatka
john kosmatka
    Member
  • Members
  • PipPipPipPip
  • 429 posts
  • LocationMilwaukee, WI
Posted 09 February 2004 - 01:19 PM
Just got my R230 and a set of axles for free :-D . I will be doing this swap when it warms up outside. Think I will go with Ross' setup.
Z's are suposed to be driven mines just sitten.
76'280z chassis awaiting 83' turbo drivetrain
77'280z auto-x project
92' Sentra SE-R fully prepped rally car
02' WRX Wagon stg 2 dd
#29 Mike Mileski
Mike Mileski
    HybridZ Supporter
  • Donating Members
  • PipPipPipPip
  • 320 posts
  • LocationTucson, AZ
Posted 10 February 2004 - 11:01 AM
Z-Dreamer wrote:
"So, are the stub axles the only weak link left?"
I would have to say yes. I know that there's been very few stub axle failures ever discussed in the forum, but it would be nice if a stonger stub axle could somehow be adapted into the stock rear housing. Its been mentioned that Jim Biondo (past list member?) converted some Corvette stub axles to work but Pete Paraska has been unable to find any documentation on this swap. Has anyone else ever ventured into this little known area of adapting different axles, other than the 27 spline (I think)280Z ones?
Mike Mileski
Tucson, AZ
#30 rags
rags
    Member
  • Members
  • 1215 posts
  • LocationWestwood, NJ
Posted 19 February 2004 - 09:24 AM
Woo hoo!! I just got the diff and CV axles for $150 from a 95 Q45. Now I just have to find another set of CV axles and the shortie axles themselves. Hey Tim, how is your contact for CV axles? PM me!
#31 74_5.0L_Z
74_5.0L_Z
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPip
  • 938 posts
  • LocationRockledge, FL
Posted 25 February 2004 - 02:08 PM
I was wondering.... Are both ends of the new CV axle able to change length? I ask this question because the old outer was fixed in length and the old inner could telescope to compensate for changes in length. If both ends of the new CV axle are free to telescope you may have a problem. You will have added an additional degree of freedom to the axle without adding an additional constraint. This will cause the position of the axle to be indeterminate, and may lead to vibration.
#32 Tim240z
Tim240z
    Administrator
  • Members
  • 5161 posts
Posted 25 February 2004 - 02:15 PM
The cage cannot move on the shaft, but both assemblies can move within the 'cups' or 'housings'. It is not unlike the OEM setup.
Tim
#33 blueovalz
blueovalz
    HybridZ Supporter
  • Donating Members
  • 3291 posts
  • LocationLittle Rock, Arkansas
Posted 26 February 2004 - 05:10 AM
I cannot address 74_5.0L_Z's concern, but I know that on the ZX cv jointed shafts, a spring on one (moveable end) end pushes the shaft against a nylon button in the other joint at the other end of the half-shaft keeping the shaft always positioned inboard. This also povides constant pressure on stub axle as well.
The joints used on German makes use the same type of cage set-up, with no spring at all, but the grooves that the balls ride in are much shorter allowing only about 1/2" of movement on each end.
#34 Z-TARD
Z-TARD
    Member
  • Members
  • PipPipPipPipPip
  • 704 posts
  • LocationCALIFORNIA
Posted 22 April 2004 - 06:23 PM
I just finished breaking down my CV shafts from an Infiniti J-30 R-200 VLSD rear end (Pretty sure its an R-200 short nose). Surprisingly, the CV joints look nearly identitcal to the R-230 CV's in Tims pictures. Close enough that it may be possible for the Moser R-230 shafts to work with the J-30 CV's. How many splines do the R-230 shafts have, and what is their OD at the splined section? The J-30 shafts are 27 spline at 1.160" OD on the splines. Here are some pics of the shaft after disassembly:
http://hybridz.org/n...normal_J-30 CV%
Posted Image
Hopefully someone with the R-230 shafts will chime in.....
72 240Z "Money Pit/ Zedzilla"
78 280Z "The Turd"(SOLD!! for $200.00)
98 Jeep Cherokee Type "R", JDM Drift Spec "Junkyard Support Vehicle"
#35 Z-TARD
Z-TARD
    Member
  • Members
  • PipPipPipPipPip
  • 704 posts
Posted 22 April 2004 - 06:26 PM
For some reason one of the pics didn't load, here goes try #2:
Posted Image
#36 Tim240z
Tim240z
    Administrator
  • Members
  • 5161 posts
Posted 22 April 2004 - 06:47 PM
Splines are the same, but it appears that the grooves and shoulders are different.....
Tim
#37 Z-TARD
Z-TARD
    Member
  • Members
  • PipPipPipPipPip
  • 704 posts
Posted 22 April 2004 - 07:10 PM
I have a lathe at work, I'm pretty sure I could modify the moser shafts to work with these joints. Maybe. The race on the R-230 shaft looks a little different than mine. Mine doesnt have the turned down portion on the internal splines to fully seat on the shaft so the c clip can go on. It appears that the shaft is releived on mine instead.
#38 Tim240z
Tim240z
    Administrator
  • Members
  • 5161 posts
Posted 22 April 2004 - 07:29 PM
I believe that after any machining, which will be difficult due to the heat treating/hardening, the part will need to be rehardened/heat treated.
#39 Z-TARD
Z-TARD
    Member
  • Members
  • PipPipPipPipPip
  • 704 posts
Posted 22 April 2004 - 07:43 PM
I think that only applies if it is just surface hardened, where the hardened area is only a few thousandths of an inch thick. I'm pretty sure that CV shafts are hardened all the way through like knife blades, so I should be ok to machine on it as long as I go slowly and use coolant to keep everything cool. As long as it never gets above about 400 F while machining it shouldn't affect the heat treatment.
Mike
#40 Tim240z
Tim240z
    Administrator
  • Members
  • 5161 posts
Posted 22 April 2004 - 08:26 PM
For OEM yes, but at least with the Speedway shafts, they are fully hardened!
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
