??toyota calipers??
79-85-solid rotor calipers are all the same, 4runner intro in 84'.
86-95 vented rotor. pick up and 4 runner-
4 cyl calipers have staggered piston sizes 1.15" and 1.5".
V6(started in 89') pickups and 4runners all use the same calipers, 1.5" and 3 fins on the outside of the caliper. I don't know if the 1.5" calipers started in 89' with the intro of the V6 though or a little later but it's only the V6 models.
yeah I'm sure they will and at this rate I'll probably be taking this route. But what I'm trying to clarify is, are the Toyota Calipers only good on the Z's and NOT the ZX's? (another way of saying it is do those Calipers only work on the 240Z,260Z, and 280z[/size']?)
That Is Correct
If you havent yet, lots of info in the archives. Try the search feature.
You will / can spend hours answering some of your ?`s.
All righty then. I'll be buying reman- calipers for the front along with performance pads and stainless lines. Anyone here tried the MSA semi-metallic performance pads? Are they worth the money versus stock replacement pads? The stainless are definitely in for sure.
