RB20/25/26/30 Links
  • Please log in to reply
69 replies to this topic
#21 RB26powered74zcar
RB26powered74zcar
    XXXXXX
  • Super Moderators
  • 4471 posts
  • LocationLake Charles, Louisiana, 70605
Posted 26 December 2005 - 01:06 PM
Credit: AKWIKZ
oil pump seal: 13510-19V00
crank seal: 12279-5L310
RB26dettZ pics
th_April_2012006.jpg ®
#22 RB26240Z
RB26240Z
    Member
  • Members
  • PipPipPipPip
  • 131 posts
  • LocationLos Angeles, CA
Posted 26 December 2005 - 02:54 PM
Here is another site with part #s and info.
http://www.mirageaut...ts.com/GTR.html
#23 RB26240Z
RB26240Z
    Member
  • Members
  • PipPipPipPip
  • 131 posts
Posted 26 December 2005 - 03:02 PM
This is another site with manuals. It's $5 per section if you want to download the pdf.
http://www.repairmanual.co.nz/
#24 Ed260Z
Ed260Z
    Member
  • Members
  • PipPipPipPipPip
  • 533 posts
Posted 27 December 2005 - 05:09 PM
Are these guys smoking Crack. It's like $5 a page. I can get the whole Manual off Ebay for $10.:cuss: :eek:
And I downloaded an R33 Manual for $0 from a web site. It covers the RB25 & 26
#25 RB26powered74zcar
RB26powered74zcar
    XXXXXX
  • Super Moderators
  • 4471 posts
Posted 27 December 2005 - 05:44 PM
See if this link works>>
RIGHT CLICK AND SAVE AS:
http://www.planetkin...vice_manual.pdf
RB26dettZ pics
#26 HakosukaJD
HakosukaJD
    Member
  • Members
  • PipPipPip
  • 98 posts
Posted 27 December 2005 - 05:51 PM
I also have a number of part guides in Japan to include "HyperRev" and "Street Perfect Tuning".
If you have questions about aftermarket part costs in Japan, its easy for me to check.
I also make periodic trips to Upgarage...if I find something interesting (like clutches for example) I'll take pics with the phone and post. They typically have a number of RB parts.
Old School vs Young pups
Posted Image
#27 RB26powered74zcar
RB26powered74zcar
    XXXXXX
  • Super Moderators
  • 4471 posts
Posted 25 February 2006 - 04:00 PM
**Some more good info I ran across over on RaceBread**
This was the post I read>> " so I bought a timming belt tensioner for an 84-89 300zx from advance auto for $15. I compared it with the rb tensioner and it has exactly the same dimensions. I put it on and it seems to work fine. "
http://racebread.com...pic=951.new#new
RB26dettZ pics
#28 RB26powered74zcar
RB26powered74zcar
    XXXXXX
  • Super Moderators
  • 4471 posts
Posted 12 May 2006 - 12:47 PM
Oil Filter By-pass Adapter for RB26 -- Earl's 1178ERL - 3/4-16... Earls has ones with thermostats built in
RB26dettZ pics
#29 Evan Purple240zt
Evan Purple240zt
    Member
  • Members
  • PipPipPipPipPipPip
  • 1598 posts
  • LocationMadison area, WI
Posted 17 May 2006 - 07:57 PM
www.jgycustoms.com
Greddy intake manifold
Custom 10lb flywheel (265 bucks)
Top feed fuel rail
Also, Pallnet on this site and zcar.com can make top feed rails as well for both the 20s and 26s.
1995 240sx....
1972 240z RIP
#30 240Z_Master
240Z_Master
    Member
  • Members
  • 1470 posts
  • LocationOrange County, CA
Posted 18 May 2006 - 07:03 AM
www.jgycustoms.com
Top feed fuel rail
Also I can get the GReddy Intake Manifold cheaper than JGY
"[Posted Image "
10/70 Datsun 240Z RB25DET with too many goodies to list...
#31 RB26powered74zcar
RB26powered74zcar
    XXXXXX
  • Super Moderators
  • 4471 posts
Posted 18 May 2006 - 10:23 PM
heres what is aplicable to the rb20/25/26 unless noted.
head studs:
rb20/25 202-4301
rb26 202-4207
rod bolts:
z32 dohc vg30 bolts were reported to work on the rb25/26 but will not work on the rb20 (rod bolts are too long for rod, verify length of rb25/26 botls)
pn for z32 rod bolts 202-6004
use sr20 bolts, may need slight trimming 202-6005 x2 (2 sets req'd if using kit)
or alternatively order (rod bolts and nuts respectively)
12x ar3.67-1
12x n502
rb20 rod bolts ONLY : 202-6003 (l24 late,l26,l28 rod bolts)
main studs:
this is from my measurements of my stock bolts and my block
rb20/25/26 except rb30, again verify lengths and sizes.
3x am4.600-1lb
11x am4.125-1lb
14x 200-8519
14x 300-8344
CREDIT
carl (RaceBread.Com)
RB26dettZ pics
#32 RB26powered74zcar
RB26powered74zcar
    XXXXXX
  • Super Moderators
  • 4471 posts
Posted 25 May 2006 - 11:18 PM
Found this on GT-R register site;
11010/11000-05U*0 - R32 (80 in early cars, 00 in later cars), R33, R34 standard block
11000-24U00 - R33, R34 N1 Block
11000-RRR45 - New Nismo Block
"I suppose the rumor that the R32's are tougher may relate to the early 80 blocks. The other thing is that the metal gets stronger as there is less stress, de-stressing is done by time and/or temperature cycling, and R32 block is older and likley to have been through more temperature cycling.
The N1 block has thicker walls on the cylinders and smaller oil channels to the head, like the tomei items. The Nismo Block is designed for 2.8l conversions it has even thicker walls, thicker top section to the head and maybe revised water channels."
#33 Sven
Sven
    HybridZ Supporter
  • Donating Members
  • PipPipPipPip
  • 274 posts
  • LocationNM
Posted 10 June 2006 - 02:48 PM
This shop sells new and used JDM parts. They also have several RB's and various front clips. BUT, they are in Australia...
http://www.tweakit.n...ex.php?cPath=59
Sometimes nothin' can be a real cool hand...
'73 240z 3.1 Mikuni,Mikuni,Mikuni - the OD Green Z
'73 240z "The Driver", soon to steal engine from ^^^
'77 280z -spread across three states in pieces, SBF'ed eventually
'85 500SEC I refuse to drive nothing but the very best! (of 1985...)
'00 F250 7.3 PSD mostly in one piece
'91 Mustang Coupe - Dust collector, forgotten step child
#34 stony
stony
    RB Moderator
  • Super Moderators
  • 4286 posts
  • LocationSyracuse Utah
Posted 10 June 2006 - 09:31 PM
its in other threads but i guess here it will be easier to find.
link to the ATI damper set.
http://www.atiperfor...s/damnissan.htm
and the powerglide rb26 adapter kit.
http://www.atiperfor...apterk/akit.htm
if you plan on going to the track with a rb26 mated to a auto you will be in the catagory that will require a SFI damper and flex plate so you might as well get it when you do the swap. IM pretty sure in stock trim the rb26 mated to a auto wil get you into the hi tens easy at somewhere around 123mph.
5.3 truck motor, BTR stage 2 cam, BWs480, custom intercooler, AEM Infinity, 2 speed powerglide, Fully built Ford 8.8, 4:56 gears/spool, 4 link suspension.
#35 RB26powered74zcar
RB26powered74zcar
    XXXXXX
  • Super Moderators
  • 4471 posts
Posted 17 August 2006 - 10:27 AM
While surfing around, I found this info on RaceBread.com Thanks Carl H
heres what ive found and is aplicable to the rb20/25/26 unless noted.
head studs:
rb20/25 202-4301
rb26 202-4207
rod bolts:
12x ar3.67-1
12x n502
main studs:
3x am4.600-1lb
11x am4.125-1lb
14x 200-8519
14x 300-8344
Carl
_______________________________________________________---
hope this helps - joel
RB26dettZ pics
#36 Guest_boostncalais_*
  • Guests
Posted 17 September 2006 - 06:40 AM
for RB30ET visit www.calaisturbo.com.au
even have RB25/30 conversion guides / part lists etc
#37 RB26powered74zcar
RB26powered74zcar
    XXXXXX
  • Super Moderators
  • 4471 posts
Posted 17 September 2006 - 12:23 PM
Here's a list of RB parts supliers that will ship to us here in the U.S.
http://www.xs-engineering.com/
http://www.rbmotoring.com/
http://www.theskylineshop.com/
http://www.nengun.com/
http://www.coximports.com/
http://www.dynamicautosports.com/
http://www.perfectrun.com.au/
http://www.japsalon.com/
http://www.greenline.jp/
http://www.whifbittz.co.uk/
http://www.justjap.com/
http://www.signalaut...p/USAindex.html
http://www.more-japan.com/
http://www.jarcoinc.com/
RB26dettZ pics
#38 stony
stony
    RB Moderator
  • Super Moderators
  • 4286 posts
Posted 21 September 2006 - 05:42 AM
Wont fit with a front sump. you have to use the rear sump pan.
#39 RB26powered74zcar
RB26powered74zcar
    XXXXXX
  • Super Moderators
  • 4471 posts
Posted 02 November 2006 - 12:57 PM
Damn Joel, you're doing a mighty fine job of compiling that information. We are all thankful.
***** RB25DET Rear Transmission Seal *****
OEM Nissan Part #
32136-01G10
Thanks Jamie, it will only help those that :search: thru this whole thread though....
RB26dettZ pics
#40 RB26powered74zcar
RB26powered74zcar
    XXXXXX
  • Super Moderators
  • 4471 posts
Posted 02 November 2006 - 12:59 PM
OEM Nissan Part #
32136-01G10
RB26dettZ pics
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
