LS1 Car Club! Post yours!
  • Please log in to reply
95 replies to this topic
#81 Mikelly
Mikelly
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPipPipPipPip
  • 6285 posts
  • LocationVirginia, United States of America
Posted 14 January 2015 - 04:35 PM
LS3 based 403 stroker using Callies Compstar crank and rods, along with SRP pistons. The heads are L92 and the injectors are 48#. Intake is a stock Ls3 and the Tbody is a nick williams. Oil system on this one is a DRYSUMP from Nutter Racing Engines. The lines are Parker Pushlok and the tank is a butlerbuilt square 4 gallon. We plumb it with a Moroso -16 vent tank and also vent the PCV system with twin tanks plumbed to both chambers of the top of the motor. Everything is managed by the FAST XFI and XIM systems and all data is monitored with the integrated FAST DASH with data logging.
The Drivetrain consists if a custom T56 I hand built, and a Ford 8.8 rear IRS, that I also completely rebuilt. The car is NOT a street car and is going to start the 2015 season as a Time Trial car in NASA and move over to wheel to wheel in VINTAGE Outlaw.
Follow me on FB at Mike's Hobby Shop!
I will not be a spectator in the sport of life!
mjk 1994
#82 streetrat18201
streetrat18201
    Newbie
  • Members
  • Pip
  • 6 posts
  • LocationWashington
Posted 12 June 2015 - 09:59 PM
75 280z
Jci motor/trans mounts
Stock 04 5.3 iron block
08 pistons and rods
08 crank
243 heads (mild work)
Arp rod bolts/head studs
Comp cam (big)
Flipped truck manifolds
V band everything
Gt45r turbo
Ls1 intake truck throttle body dbc
F body accessories/just crank, alternator water pump
Champion 3 row radiator
2 Spal 12" pullers
Billet fuel rail
80# injectors
Th400
Trans brake, rmvb
Hurst quarter stick shifter
Shortened 01 mustang GT 8.8 rear
15 gal fuel cell
A1000 pump
-8 feed/return fuel line
Magnafuel regulator
Energy bushings
Lots more, just can't think of it right now
#83 memosauto44
memosauto44
    Newbie
  • Members
  • Pip
  • 2 posts
  • Locationsalinas ca
Posted 24 September 2015 - 08:10 PM
71 240z with 5.3 241 heads ls1 intake used crx racing engine mount kit with t56 transmission
#84 Boy from Oz
Boy from Oz
    Member
  • Members
  • PipPipPipPip
  • 479 posts
  • LocationSydney
Posted 01 October 2015 - 05:00 PM
LS1
t56
Long tube extractors (headers)
GM, IRS, LSD differential
Wilwoods
Adjustable LCAs
Dayton wire knock-offs
PWR radiator - relocated forward of engine bay
Aluminium fuel tank
GM in-tank fuel pump
Puckett, 250 GTO, body
RHD
https://vimeo.com/194912950
Edited by Boy from Oz, 14 December 2016 - 02:57 PM.
#85 stony
stony
    RB Moderator
  • Super Moderators
  • 4285 posts
  • LocationSyracuse Utah
Posted 26 November 2015 - 07:14 AM
After 15 years I decided to move away from my beloved RB and jump over to the dark side. As most people can attest to once you go fast its like a drug and you want more and more. Well I had reached the depth of my wallet with the rb. If I wanted to go faster and not eat up cranks and rods, I needed to drysump. I crunched numbers ,sold the rb and got into a truck motor and everything I needed to go fast and had enough left over to have anti roll installed and a parachute ;> .
So here it is.
2000 Silverado 5.3 w BTR stage 2 turbo cam, rocker trunnion upgrade, titanium springs and retainers, LS7 MLS head gasket, a hi volume/pressure melling oil pump, 1600 cc injectors spraying E85, and a Borg warner S480 turbo.
This will be mated to a powerglide with 3:70ish gearing in a 8.8 that is 4 linked.
This was a finished project that I'm swapping motors so if you want the specs on the rest of the car swing over to the rb forum and check out my builid thread over there.
I have a build thread going called Unnatural Aspiration part 4 ;>
5.3 truck motor, BTR stage 2 cam, BWs480, custom intercooler, AEM Infinity, 2 speed powerglide, Fully built Ford 8.8, 4:56 gears/spool, 4 link suspension.
#86 datsunls1
datsunls1
    Newbie
  • Members
  • Pip
  • 22 posts
  • Locationhobbs nm
Posted 10 December 2015 - 12:10 PM
Any body run a stock brake master cylinder!!!
#87 spitsnaugle
spitsnaugle
    Always Here
  • Members
  • PipPipPipPip
  • 110 posts
  • LocationDayton Ohio
Posted 19 January 2016 - 10:39 AM
Pardon the dust, its been a slow moving project.
The LS1
  • Holley XP 750 Carb + Holley Intake
  • 211/230 .558/.552 122.5 Cam
  • 1.7 ratio rockers,
  • mild ported
  • MSD 6LS Ignition Controller
  • LS2/3 Coils
  • Meziere electric water pump,
  • CX racing long tube headers (not pictured)
  • Hoke Performance (beta test) motor and trans mounts.
Edited by spitsnaugle, 19 January 2016 - 10:50 AM.
1971/2 Datsun 240z, Currently swapping in a mild-built carb'd LS1.
Daily Driver: '09 Jetta Sportwagen TDI - Malone Tuned,  45+mpg
#88 trackzpeed
trackzpeed
    Always Here
  • Members
  • PipPipPipPip
  • 438 posts
  • LocationRedding
Posted 19 January 2016 - 12:34 PM
They are never done... but at least it's on the road and track.  72 240Z, LS1 T56, CXracing, 3:90 R200 LSD.....
  • Attached File  037.JPG   93.99KB   4 downloads
  • Attached File  012.JPG   120.64KB   6 downloads
  • Attached File  001.JPG   103.02KB   2 downloads
  • Attached File  008.JPG   152.26KB   4 downloads
  • Attached File  002.MOV   24.34MB   12 downloads
Edited by trackzpeed, 27 January 2016 - 01:14 PM.
#89 RebekahsZ
RebekahsZ
    Life Member
  • Donating Members
  • 5355 posts
  • LocationFlorence, Alabama
Posted 19 January 2016 - 08:25 PM
Spitz-how do you power the alternator with the electric water pump?
1972 240z, purchased in 1991 for $900. Bone stock LS2/T56/DBW from 2006 GTO, swap completed in 2011. 400rwhp/435 rwtq. 2400# minus driver. JCI swap, Mantic ER2 clutch kit, JTR headers, single exhaust, Borla muffler, MGW shifter, M2 Differentials shortened Z31 CV axles, Z31 CLSD R200, Chequered Flag Racing billet stubs and companion flanges. MSD 2-step, Hurst roll control, both operated from switches on clutch pedal. 9" Hoosier drag slicks on Weld Draglites, 245/45/16 Hoosier A6/R6 on 16X8+10 Rota RBR. 225/250 sectioned coilovers, Koni 8610-1437RACE shocks, DP and EMI camber plates, MM shortened rear control arms, TTT front control arms, poly and aluminum bushings. Top speeds: Ohio Mile 174mph, C/GMS class record holder, best 1/8 mile 6.96 at 100mph, best 1/4-mile 11.0 at 126mph, best 60' 1.43, best 1/2-mile 148mph at GA 1/2-mile. Home Track-Jake's Dragway, Moulton, AL. SCCA autocross club - TVR, Huntsville, AL. Lets race!
#90 spitsnaugle
spitsnaugle
    Always Here
  • Members
  • PipPipPipPip
  • 110 posts
Posted 20 January 2016 - 08:27 AM
Uh, say what. lol. Its a bit vise versa :)
Unless you're talking belt wise... then its pretty simple:
But.... that alternator is too big for my liking. So I want to fab up a mini alternator on the low passenger side.
#91 RebekahsZ
RebekahsZ
    Life Member
  • Donating Members
  • 5355 posts
Posted 20 January 2016 - 07:01 PM
Thanks!  Absolutely incredible!
#92 Fullauto
Fullauto
    Moving Up
  • Members
  • PipPip
  • 47 posts
  • LocationAustin
Posted 06 March 2016 - 03:44 PM
1978z
original paint
LS1 T56
102mm throttle body
3.91 os giken L/S differential
Techno toy suspension
Techno wilwood big brakes
CX racing mounts, headers and y pipe ceramic coated Lava wrapped
MGW shifter
Borla muffler
Frame rails
Bumper conversion
T56 tail mod for speedo
All original guages
Painless engine wiring
Alignment by Soul Speed
Tuned by Aikmam Performance
Rota 16s
Michelin pilots
Edited by Fullauto, 29 October 2016 - 01:53 PM.
#93 Stock Car Mafia
Stock Car Mafia
    Can Charge Rent
  • Members
  • PipPipPipPipPip
  • 500 posts
  • LocationMinneapolis, MN
Posted 09 June 2016 - 09:59 AM
1978 280Z - 2,560 lb. after swap
 - LS2/T56 pullout from an 05 GTO w/ stock harness
 - Hawks Third Gen weld in motor and transmission mounts
 - C6 LS3 Oil Pan
 - Hawks Third Gen Longtube Headers
 - 3" Dual exhaust with custom X-pipe and Dynomax Race Bullets
 - Ported and polished Intake and TB
 - VRX5 Camshaft: 236/238 .601/.605 113+2 LSA
 - Mightymouse catch can
 - Monster Stage 3 clutch w/ 18 lb. flywheel
 - 3" Aluminum driveshaft with billet slip yoke - 9 lb.
 - Z31T CLSD R200
 - Chequered Flag shortened half axles
 - Chequered Flag companion flanges
 - Tilton 7/8" Clutch MC
 - Wilwood 1" Brake MC
 - S12W Toyota vented brake upgrade
 - 14 gal. Jeg's fuel cell
 - Bosch 044 fuel pump
 - -8AN fuel lines
 - Ground Control weld in coilover kit
 - Tokiko Illumina shocks
 - 225/250 springs
 - Energy Suspension polyurethane bushing kit
 - Rota RB-R 17" x 9.5" on all 4 corners
Started the swap November 18th and turned the key on May 27th.  Started driving it May 30th and haven't looked back!
Edited by Stock Car Mafia, 08 July 2016 - 07:17 AM.
Loose is fast and on the edge of out of control.
#94 G-Tech
G-Tech
    Moving Up
  • Members
  • PipPip
  • 39 posts
  • Locationrochester ny
Posted 13 October 2016 - 01:00 PM
:1983 280zx
:L33 5.3 aluminum block bored to 5.7, ls2 dart heads, forged piston/rods,ls6 intake 406whp
:RPM t56 trans rated for 750hp
:R200 w/ 3:54 gears and quaife internals
:modified JTR mounts for SBC to work with the Ls motor
:special Canton oil pan to get the motor low enuff
:headers are the biggest problem, I modified Billy boat c5 shorty headers
:made my own dual 2 1/2 to single 3 1/2, all stainless, had to use oval pipe to get over sub frame
:my grandfather purchased the car in 1984, then my dad had it and I bought it from him in 2004
started with a SBC swap in 2008 but it made the car nose heavy and I still felt it was out dated.
in 2010 the Ls swap was done.im jealous of all the stuff the older Z's have for Ls swaps, zx's have nothing
: A friend and I fully restored the body and painted the car from blue to black
:Arizona z car brakes
:techno toys front shortened coilovers
:custom made 420lb rear springs (very needed to reduce squat)
:whitehead performance 300m 39 spline stub axles
:300zxt cv-joints
:Boze custom made rims 17x7 and 17x8
:shaved side markers, antenna, side trim, rear wiper, custom taillights
:aeromotive fuel system, modified gas tank to be gravity feed.
: on and on and on, ill just stop there
everything done by myself and help from friends and family. many,many long nights and dedicated hours. And a wife that supports me taking the time to do it.
BUILT NOT BOUGHT!!!
Edited by G-Tech, 25 October 2016 - 01:52 PM.
#95 G-Tech
G-Tech
    Moving Up
  • Members
  • PipPip
  • 39 posts
Posted 13 October 2016 - 01:08 PM
I really hope this post can inspire some 280zx owners to do the swap. there isn't many that have completed this swap. the car is very dependable. 2918lbs. 50/50 weight. runs 11.9 @116mph in the 1/4 mile. and I beat on her all the time. awesome swap to do. im very willing to help with any questions.
Edited by G-Tech, 24 October 2016 - 06:29 PM.
#96 DomiNATE
DomiNATE
    Newbie
  • Members
  • Pip
  • 4 posts
  • LocationMaryland
Posted 14 December 2016 - 01:01 PM
Hi guys,
New to the Z world, I just bought this car from a gentleman in Illinois.  Seemed like he really cared about the car but had to let it go.  I'm not sure if he was a poster on this forum but he did mention it.
It's a 1975 280z.
Most of this is quoted from the seller's listing.  There's a lot more to say but here's the meat and potatoes.
1. 1999 GM LS1 from Trans Am with 118,000 miles, GM unlocked computer, PSI Conversions harness
New water pump, oil pump, timing chain, starter, rebuilt injectors (Oside Tiger), fuel pump (MSD), fuel regulator,
(Corvette regulator and filter) Sanderson ceramic coated headers, MSD plug wire with heat boots, braided AN fuel line, PSI harness,new valve cover gaskets, intake gasket, silicone intake hoses, K&N filter, LS6 converted valley cover, new starter
3” into 2.5” all stainless, tig welded exhaust with Vibrant resonator and Magna Flow muffler, all connections are V-bands.
2. Professionally rebuilt 4L60E transmission and torque convertor (less than 500 miles), OEM Camaro shifter with custom weldedand smoothed shifter box housed in trans tunnel, custom solid brass shift knob (looks like a manual),
shortened shifter, JCI drive shaft, OEM rear end. The rear suspension is stock for the most part with exception of
T3 coilovers and all poly bushings.
6. CUSTOM one-off American Racing forged wheels, model VN477, satin black 17x9 and 17x9.5
Brand new Continental Extreme DWS tires 245/45-17 front, 275/40-17 rear
Custom yellow “continental” tire letters
Technotoy Tuning coil overs (front and rear), front lower control arms, TC rods, triangulated front strut bar (not installed)
SilverMine Motors Wilwood brake conversion, front and rear, powdercoated red
Wilwood master cylinder and proportioning valve
Technotoy front camber plates
Somewhere between Baltimore and DC. 1975 280z, LS1 motor, 4L60E trans.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
