wheels/tires
  • Please log in to reply
66 replies to this topic
#41 G-rib-73-240z
G-rib-73-240z
    Member
  • Members
  • PipPipPip
  • 65 posts
Posted 29 October 2008 - 09:19 PM
4 on 4-1/2 (114.3 mm)
Acura - Legend '86-'89
Buick - Special '61-'63
Chevrolet
Corvair all 4-bolt
Chevy II all 4-bolt
Sprint '85-'87
Nova ('61-'70)
Datsun/Nissan - most models to '89
Dodge Colt '79-'88
Dodge Colt (early)
Ford
Mustang all '65-'68 4-bolt
Falcon, Maverick, Granada all 4-bolt
Mazda - 626, RX7 '83-'87 ????
MGA, MGB, MGC
Olds - F-85 '61-'63
Plymouth - Arrow, Sapporo '79-'88
SAAB all ???
SAAB - 900 to '87
Toyota - most exc. MR2 and P.U. to '89
Triumph TR 1..6
so does that mean that stock lug spacing on a 240z is 114.3 mm(4 1/2 in)? i just want to make sure im reading this right. im not the sharpest tool in the shed, ya know?
#42 grumpyvette
grumpyvette
    Moderator
  • Members
  • PipPipPipPipPipPipPip
  • 3566 posts
  • Locationloxahatchee florida
Posted 22 January 2009 - 11:39 AM
wheel repair, and widening and narrowing
ok many times youve seen a custom set of wheels you like but they don,t come in the correct width for your application, or youve got great wheels but youve screwed one up and it needs repairs, sometimes you just want wider tires and your current wheels won,t fit that tire width correctly or youve seen some killer (ford, caddy,nissan ETC,) wheels but they don,t come in your ideal bolt pattern or width.
theres several shops that specialize in doing the necessary mods and reworked wheels can be just as strong or stronger than new wheels if the works done correctly....
BEFORE LOOKING INTO MODIFYING WHEELS DO AN EXHAUSTIVE SEARCH ON NEW WHEELS,THAT MAY WORK CORRECTLY, SIMPLY BECAUSE THE AVERAGE COST, OF MODIFICATIONS TENDS TO RUN BETWEEN $125-$200 PLUS PER WHEEL,(IVE SEEN STOCKCAR STEEL WHEELS DONE FOR UNDER $70 EACH) and VERIFY THAT THE TIRES AND BRAKES YOU WANT ARE AVAILABLE AND WILL FIT THE NEW RIM SIZE
example
I had a dana 60 rear differential from a PLYMOUTH BARRACUDA installed in my CORVETTE , the bolt pattern was differant and I wanted disc brakes that would not fit the 15" drum brake MOPAR wheels that looked crappy anyway, and 17" wheels were not even an option in the 1970s on CUDAs
so if I wanted matching 11" wide wheels what can you do? well, its not cheap but it is something you can do, and with STEEL WHEELS its a good deal cheaper than with aluminum in many cases. but you can have almost any wheel fabricated, to match the lug pattern, back spacing, etc. you want, if you can supply the basic wheels of the correct inner and outer dia. the work cam be as simple as cutting and rewelding and reballancing the wheels, it can be far more complicated so ask lots of questions before commiting to the project, and try to deal locally as it tends to remove some possiable problems if you can deal face-to-face with the shop.
the key is finding a RELIEABLE SHOP THAT DOES QUALITY WORK, your local stock car track guys should be very familiar with who does the work in your area on steel wheels and many times the same guys repair and modify aluminum and custom wheels.the KEY in getting a good result is in dealing with a quality shop with a long history of good customer feed back and doing VERY PRECISE MEASSURMENTS and suppling a PRECISE diagram , because your going to get almost exactly what you request in back spacing, dimensions and lug patterns , if you measure wrong your screwed and youll need decent wheels to start with, (sometimes 8 old wheels will be required to build 4 new wheels).
heres three shops off the internet, and one had multipule links with bad =feedback
http://www.weldcraft...ls.com/Wide.htm
http://www.thewheelsmith.net/
heres two that do custom repairs and widening
http://www.stocktonw...el_widening.htm
stocktons had lots of bad customer feedback pop up when I did an internet search
more wheel related info.
http://www.carcraft....harticles/3636/
http://www.high-impa...llustration.htm
http://www.custom-wh...l-backspace.htm
http://www.rsracing.....html#backspace
http://www.intercoti...dy_true-mph.htm
http://www.kormanfas...om/ttiredia.htm
http://www.rsracing..../prod-index.asp
http://www.rsracing....ssary.htm#patch
http://www.miata.net...e/tirecalc.html
http://www.geocities...es/tirediam.htm
http://www.dougrippi...lwood Brake Kit
" IF YOU CAN'T SMOKE THE TIRES FROM A 60 MPH ROLLING START YOUR ENGINE NEEDS MORE WORK!"
#43 boardkid280z
boardkid280z
    Member
  • Members
  • PipPipPipPip
  • 216 posts
  • LocationOKC, Oklahoma
Posted 06 April 2009 - 11:25 AM
I didn't see this link anywhere in this thread and it is a great reference for stock wheels with dimensions and weights.
http://kmhafer.datsu.../wheelchart.htm
(if the link quits working, the page is on http://www.dimequarterly.com under Technical -> Suspension)
Originally Posted by BRAAP
"If you want professional information, make an effort to ask in a professional manner..."
1978 280Z: project car. NA, turbo, supercharged, and now turbo again.
#44 iHeartTouge
iHeartTouge
    Member
  • Members
  • PipPipPip
  • 65 posts
  • LocationRichmond, VA
Posted 21 April 2009 - 08:06 PM
www.citytireonline.com
This is the only place I order my tires from. Great customer support and great prices.
Slide 'n Hide
#45 DeleriousZ
DeleriousZ
    Custom user-title, DENIED!
  • Members
  • PipPipPipPip
  • 240 posts
  • LocationVancouver BC Canada
Posted 29 April 2009 - 11:53 AM
all z31's except 84-86 n/a's had 5 bolt hubs. 5x114.3
Posted Image
88 z31t - under construction
#46 jnonni99
jnonni99
    Junior Member
  • Members
  • Pip
  • 9 posts
Posted 04 May 2009 - 10:58 AM
Hoping to put 16" tires and wheels on my 75 280z. Has anyone done this and it looked good (proportionally)? Did they rub on the wells? Did ride comfort increase or decrease over 15"? Tire size, wheel size to make it work (off sets)? Thank you!!!
#47 Woza01
Woza01
    Junior Member
  • Members
  • Pip
  • 10 posts
  • LocationMandurah, WA, Australia
Posted 27 May 2009 - 03:55 PM
Hell yeah, 16's fit easily...Im going to be fitting 18's on mine soon !
#48 Z lion 71
Z lion 71
    Junior Member
  • Members
  • PipPip
  • 25 posts
  • LocationSAN DIEGO
Posted 21 November 2009 - 06:34 AM
hey great info this will help when i get my next set of wheels.
#49 vega
vega
    Member
  • Members
  • PipPipPipPip
  • 384 posts
  • LocationAnoka MN
Posted 25 November 2009 - 08:33 PM
We should have a minimum and maximum to rim widths and what will fit with stock suspension somewhere.
“It's a little icebox made of Styrofoam, wood, fiberglass, and aluminum strips, ... We thought we should start a phone-sex service for penguins. ...” :/ … what will become of our children? God - help us all...
#50 crazyoctopus
crazyoctopus
    Member
  • Members
  • PipPipPipPip
  • 393 posts
  • LocationSan Diego, CA
Posted 05 January 2010 - 08:50 AM
I remember seeing somewhere that to clear stock coils you need at most a 4.5" or 5" backspace; anything under that (4.25, 3, etc) and you should be fine. The width of the wheel depends on backspace, and tyre size.
#51 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • PipPipPipPipPipPipPipPipPipPip
  • 12450 posts
  • LocationSeattle area, WA
Posted 05 January 2010 - 09:45 AM
No way a 4.5" or 5" backspace 13, 14, or 15" wheel is going to clear stock coils.
Jon Mortensen, owner/operator www.petdoorstore.com
#52 crazyoctopus
crazyoctopus
    Member
  • Members
  • PipPipPipPip
  • 393 posts
Posted 06 January 2010 - 06:01 AM
So then what is the maximum backspace a wheel can have on stock coils?
#53 crazyoctopus
crazyoctopus
    Member
  • Members
  • PipPipPipPip
  • 393 posts
Posted 05 February 2010 - 07:29 PM
well i just ordered a set of 15x10 with 4.5" backspacing all around so i'll tell you if i need a spacer, but from all of the research that i have put into it 4.5" is the maximum that you can do with stock suspension. i'll post pictures as soon as i get them and install them
#54 dernikmatute2008
dernikmatute2008
    Junior Member
  • Members
  • PipPip
  • 31 posts
  • LocationOrlando Florida
Posted 05 July 2010 - 01:35 PM
Posted Image
Posted Image
these are hd wheels
http://www.hd-inc.com/
they fit the z and are copy of the ssr starsharks
i think they are ok
i also like the ssr spr1 professor i think thats the name
Posted Image
good stuff
Posted Image
1982 Datsun 280ZX (Undergoing plastic surgery)
http://www.youtube.c...ernikmatute2008
#55 Danimal420
Danimal420
    Newbie
  • Members
  • Pip
  • 5 posts
  • LocationSan Diego
Posted 17 February 2011 - 04:13 PM
i think these look great on z's, i want to buy a set
Posted Image
Posted Image
Posted Image
http://www.nengun.co...lk-racing-te37v
what would be the best dimensions to get?
Edited by Danimal420, 17 February 2011 - 04:13 PM.
#56 crazyoctopus
crazyoctopus
    Member
  • Members
  • PipPipPipPip
  • 393 posts
Posted 20 February 2011 - 09:51 PM
15x10 -50
all around.
cut to fit.
<3 From the Crazy Octopus
My Blog - crazyoctopi.blogspot.com
My Photos - www.flickr.com/crazyoctopus
#57 19762802+2
19762802+2
    Member
  • Members
  • PipPipPipPipPip
  • 840 posts
  • LocationOld Colorado City, Colorado Springs
Posted 20 February 2011 - 11:10 PM
EDIT: Nevermind.
Edited by 19762802+2, 20 February 2011 - 11:11 PM.
1976 280z 2+2 Almost on the road.
Slamming a car to the ground and putting stupid wheels on it is like spandex on Rosie O'Donnell. You go ahead and get all excited about that spandex if that floats your boat. All I see are cankles.
#58 1976 zdevil
1976 zdevil
    Newbie
  • Members
  • Pip
  • 1 posts
  • Locationcherry point
Posted 25 May 2014 - 03:12 AM
Hi guys I just bought the zg wide fender flairs. For my 1976 280. They add 3 1/4" in the front & 3 3/4 to the rear. I'm wondering what is the largest & best wheel and tire setup. With the space I now have. Im Also looking for offset spec so they don't rub the suspension. It is stock for the time being. I'm obviously planning to lower the car as far as functionality always. No crazy chamber. The below pic is the look I'm going for. Thanks for you time guys.
#59 Incognitjo
Incognitjo
    Newbie
  • Members
  • Pip
  • 9 posts
  • LocationLakewood, CO
Posted 13 November 2014 - 07:01 AM
You now what I love? I love that anywhere you go in the forums regarding wheel and tire size, there is literally NO LIST anywhere that I have been able to find of verified wheel and tire combo's that work on the Z's. A whole lot of talk about what may or may not, but nothing solid. It doesnt make sense to me. It either does or does not fit, you either have to cut/roll or dont. Why cant anyone just post a flipping list of tire combos that work?
#60 Jambolito
Jambolito
    Newbie
  • Members
  • Pip
  • 1 posts
  • LocationBowie, MD
Posted 01 May 2015 - 12:11 PM
I agree Incognito, I cant find a list like that anywhere and it would be so stinkin helpful.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
