Transmission Dimensions
  • Please log in to reply
30 replies to this topic
#1 johnc
johnc
    Administrator
  • Administrators
  • 9739 posts
  • LocationLa Habra, CA, USA
Posted 27 October 2005 - 08:20 AM
Nissan Type A 4 Speed
Weight: 70 lbs.
Length (bellhousing to end of tailshaft housing): 31"
Shifter position (bellhousing to center pivot): 31"
Nissan Type B 4 Speed
Weight: 72 lbs.
Shifter position (bellhousing to center pivot): 29"
G-Force T5 5 speed
Weight: 101 lbs.
Length (bellhousing to end of tailshaft housing): 31.5"
Shifter position (bellhousing to center pivot): 29" - aftermarket Long shifter
----- John Coffey, Fabricator at Benton Performance, LLC
#2 rudypoochris
rudypoochris
    Member
  • Members
  • PipPipPipPipPipPip
  • 1339 posts
  • LocationOakland, CA
Posted 29 December 2005 - 07:28 AM
Thanks! Would you mind posting what year cars the different tannies came in. I believe the two 4 speeds are 240's and the type B was a redesign for a different length driveshaft with a different style U-joint (i think) and new location of the post Series 1 consol, or something of the sort. The 5-speed came in 280zx and beyond??? Thanks again.
1972 240z - Ford 302... Barely Running
#3 rags
rags
    Member
  • Members
  • 1215 posts
  • LocationWestwood, NJ
Posted 23 May 2006 - 04:44 AM
John,
Do you have info on the z32 and z33 tran's? Weight, lenght, etc... Also, do the VQ and VG motors use the same bolt pattern for the the bell housing?
Thanks.
Joe
#4 johnc
johnc
    Administrator
  • Administrators
  • 9739 posts
Posted 23 May 2006 - 07:14 AM
The Type A 4 speed came in the Series 1 240Z although I don't know when the cutoff was. They are easy to identify because they have a separate bellhousing.
The Type B 4 was available from the 240Z through the 280Z.
The T-5 was installed in the 280ZX turbos.
I don't have dimensions on the Z32 and Z33 transmissions.
#5 240hoke
240hoke
    Totally Addicted
  • Members
  • 1429 posts
  • LocationNC
Posted 23 May 2006 - 04:48 PM
I have a z32 transmission sitting out in the garage waiting for my adaptor. Ill try and weigh it for you guys. Its certainly more beefy then the stock unit!!!! And just a head up for those of you looking to do the swap, you can get a z32 trans for cheap. I picked up mine with 88K miles and very clean for 300 bucks including hte shifter assymbly. They are known to hold over 600hp.
Alrighty here are the deminsions,
Z32 Manual Transmission:
Length (bellhousing to tailhousing): 30.25"
Shifter Position (bellhousing to center pivot): 34.5"
Trans MOunt position (bellhousing to center of mount): 24.5"
*z32 Shifter is straight up and down unlike the shifters on the first gen trannies which slope back towards you so this helps offset the shifter location diffference.
1971 240z w/ VQ35DE
www.HokePerformance.com
Modern Performance. Vintage Style.
FaceBook Page
#6 mom'sZ
mom'sZ
    Member
  • Members
  • PipPipPipPipPip
  • 669 posts
Posted 10 September 2006 - 04:53 PM
Does anyone know the bellhousing to end of tailshaft housing length for the early 5-speed? The one that came in 280Zs? Is it the same as the type B 4 speed? Do the drive shafts interchange between the type B 4 speed and the early 5 speed ?(280Z not ZX)
#7 COZY Z COLE
COZY Z COLE
    Retired Admin.
  • Members
  • 1394 posts
Posted 10 September 2006 - 06:47 PM
Driveshafts can be interchanged between A and B and early 4 and 5 speed trannies. Shifters can not be.
Early Trannies....
F4W71A "A" type 4 speed.... Build date 69-8/71.
F4W71B "B" type 4 speed.... Build date 9/71-76.
FS5W71B "B" type 5 speed....77-78 280Z and 79 280ZX.
LARRY
Said to many times!! My uncle, brother, dad, friend, _____ has a Z just like yours..... 1975 280Z 355 SBC with WEIAND 144 PRO-STREET BLOWER, R-230 conv.
#8 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • PipPipPipPipPipPipPipPipPipPip
  • 12413 posts
  • LocationSeattle area, WA
Posted 10 September 2006 - 06:57 PM
I think you're wrong there Larry, but in a weird way.
The 69-71 diff was mounted 1" forward from the later cars, so the driveshaft for the 70 and 71 cars is 1" shorter. While it will plug on and probably work on a later car, the correct shaft for a later car would be the longer 72-78 shaft.
I know this to be true because I moved the diff back on my 70 to correct the halfshaft angles and went and got a longer shaft for it at that time.
So to answer mom'sZ's question, the 72-78 shafts are all the same as far as I know, and the length is correct for any A or B type 5 speed (including NA 280ZX). I suspect that if someone were misguided enough to put the crappy early 4 speed in a later car the later shaft would be the correct one in that case as well.
Jon Mortensen, owner/operator www.petdoorstore.com
#9 cybermecium
cybermecium
    Junior Member
  • Members
  • Pip
  • 23 posts
Posted 14 April 2007 - 07:05 PM
What 5speed transmission was used in the 80 280ZX NA? Is there a difference in splines from tranny to tranny? thanks
#10 jonus079
jonus079
    Member
  • Members
  • PipPipPipPip
  • 154 posts
Posted 18 April 2007 - 08:13 PM
any info on a t56??
Posted Image
View My Turbo 5.3l 240z project here.
#11 Six_Shooter
Six_Shooter
    Member
  • Members
  • 1466 posts
  • LocationNear: Toronto, Ontario, Canada
Posted 13 March 2008 - 04:45 PM
Doing some searching on the manual trannies to night, since I may have a 4 speed to go in my car instead of a 5 speed. The reason I say this is because I was going through the gears with the tranny sitting on the floor and could not find a 5th gear, I thought I did, once, but every time after that, I could only find 4 gears.
Is there anyway to tell? I could not find any markings, or numbers on the tranny case to identify it.
I also see on THIS page that the 280Z, not ZX could also come with a 5-speed. I know this tranny came out of a 280Z, and was pretty sure I was told it was a 1978, that would, according to that page mean that it should be a 5-speed.
Any insight into this?
Z: 152391 Project Thread
Typhony: Project Thread
My rear view mirror doesn't have a zoom feature.
#12 Zsane
Zsane
    Member
  • Members
  • PipPipPipPip
  • 109 posts
Posted 07 April 2008 - 06:10 PM
Not sure about the cutoff but I have a 77' 280 stock with a 4 speed here at the house. So they did have them.
#13 blaze73
blaze73
    Member
  • Members
  • PipPipPip
  • 73 posts
  • LocationVictoria BC
Posted 18 December 2008 - 01:08 PM
Has anyone got a weight on the Z32 trans yet?
#14 Oddmanout84
Oddmanout84
    Blank
  • Members
  • PipPipPipPipPip
  • 663 posts
  • LocationMy Garage, Massachusetts
Posted 08 February 2009 - 08:00 AM
I'd also like to see how to identify these. I say this because the only number I've found is a serial # on top of the bellhousing, not a part number. The transmission was removed at some point in this car's life, because the bottom half of the plate that seals the tranny to the engine is missing. I have no clue if the tranny was also replaced, all I know is that its a 5 speed. I don't know if there's any difference between the "A" type and the "B" type, or if the shifter hookup is different between the 280Z and 280ZX. I want to purchase a short throw shifter, but I don't want to drop money on something that's not going to fit.
I'm pretty sure this isn't a Borg Warner T5 in my car...
#15 BRAAP
BRAAP
    Administrator
  • Administrators
  • 4166 posts
  • LocationOregon
Posted 08 February 2009 - 11:53 AM
T-56 for GM LSx.
Posted Image
#16 HowlerMonkey
HowlerMonkey
    Member
  • Members
  • 1381 posts
  • LocationWest Palm Beach
Posted 15 February 2009 - 07:04 PM
Pathfinder FS5R30....Length (bellhousing to tailhousing): 28.50"
Shifter Position (bellhousing to center pivot): 27.0"
Trans Mount position (bellhousing to center of mount) forgot the number but seems to be about 25.0" to 25.5"
It also sports a very cool longshifter that angles backward such that the knob in neutral ends up about 30 inches from bellhousing.
#17 AK-Z
AK-Z
    Member
  • Members
  • 1648 posts
  • LocationAlaska
Posted 17 February 2009 - 07:47 AM
Any body know "for sure" if the SR20DET transmission bell housing is the same as a KA24DE transmission bell housing?
[URL="http://www.zippyvideos.com/70747806453375.html"]
"Sorry, this sig picture is larger than the allowed maximum of 500 x 100 pixels."
[/URL]
#18 Mack
Mack
    Member
  • Members
  • PipPipPipPipPip
  • 771 posts
  • LocationMinneapolis, MN
Posted 23 February 2009 - 12:15 PM
the bellhousing is NOT the same, you can swap them out tho. the SR20 and KA24 trans are the same internally and have the same rear covers, but the bellhousing bolt patterns are different.
I can get Z33 measurements by thursday, as I have a 6spd in my garage.
EDIT: you could get either a 4spd or a 5spd on 280Z cars, it was an option, and in 1979, you could even still get a 4spd on the 280ZX. those 280sxs have the highly desireable 3.36 R200 gears.
hey, check my website for pics of my free 280zx.
#19 spacecase70
spacecase70
    Member
  • Members
  • PipPipPipPip
  • 192 posts
Posted 18 November 2009 - 11:49 AM
any thoughts on the 82 maxima trans. I would like to know the ratios on it since i put one in my 74 ?
[SIGPIC][/SIGPIC] Looking for more power the natural way
#20 Guest_sasahdois_*
Guest_sasahdois_*
  • Guests
Posted 18 November 2009 - 05:14 PM
I think this is enough .....
I do agree with you. Those are the most effective way:icon44::shock:
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
