IC to throttle
vashonz
Just welded up a new intake pipe to go from the IC to the throttle body. I still need to weld the flange for the bypass/BOV.
I don't know if I should do the extra plumbing to recirc or just vent to atmosphere. Either will work fine because the AFM has been replaced with a MAP.
The neck was a transition piece I got from the local NAPA (they actually have some steel mandrel bends there too).
The bov fits nicely between the TPS and the fenderwell. If I still had the stock coils this location would not work.
The TB will actually be on the right side of the pipe, I thought about putting the BOV opposite the throttle, but there would have been an interference problem with the radiator.
