Picture of my trial fit. Ls1/ Datsun 510.
  • Please log in to reply
44 replies to this topic
#41 Mike kZ
Mike kZ
    Super Moderator
  • Super Moderators
  • 2521 posts
  • LocationAtlanta GA
Posted 28 March 2006 - 12:58 PM
I found it: http://www.waskomtex...ne_cooling.html
#42 rustrocket
rustrocket
    Member
  • Members
  • PipPipPipPip
  • 171 posts
  • LocationCALIFORNIA
Posted 28 March 2006 - 01:18 PM
Thanks mike.
1986 volvo 240dl
1983 porsche 930 undergoing ls3 engine transplantand suspension overhaul.
Looking for a 240z
#43 Supra510
Supra510
    Member
  • Members
  • PipPipPipPip
  • 194 posts
  • LocationNewberg, OR
Posted 28 March 2006 - 06:26 PM
I would try to keep the cooling where it is. The main reason is that the radiator sits on the lower tiebar. You are pretty much forced to have the crank pulley behind that tiebar unless you fab a new one to create clearance. If the engine's not far enough back then you can't get the pulley off with the engine in the car, or even get a wrench on the bolt.
If the crank pulley is in back of the tiebar then you have enough room to fit a decent size radiator. I have a Griffin 16X29? in my car and it fits height and width wise. You can pick those up at Summit for under 200.00 and they are meant for a V8 to begin with.
I was looking at qwik240z conversion, was the crank pulley under that tiebar?
Anthony
'71 Datsun 510 wagon, 2JZ-GTE (Supra TT engine)
http://www.cardomain.com/ride/674663
Posted Image
#44 qwik240z
qwik240z
    Member
  • Members
  • PipPipPipPipPip
  • 709 posts
  • LocationMaryland - Suburbs of Washington, DC
Posted 28 March 2006 - 06:40 PM
The crank pulley was behind the "tiebar" in my car. You could remove the pulley with the motor in the car. I had replace a broken harmonic balancer once.
I had a Griffin radiator in the car too. I think it was 22" X 13"
I agree with supra510, keep the radiator in the stock location.
ENJOY THE RIDE!
David
72 240Z
Code name:Silver Bullet
2002 LS1, w/ 6 speed
2650 pounds
340RWHP/365RW TORQUE
Posted Image Posted Image
#45 Cable
Cable
    Member
  • Members
  • PipPipPipPipPipPip
  • 1015 posts
  • LocationJackson, Ca
Posted 21 February 2017 - 09:53 AM
11 year bump....
Whatever happened with this car/setup?
Cable
-1974 Blazer 2wd: 6.0 LQ4/4L80e, BW S475 T6 Turbo
-1975 280z: Cammed 6.0 LQ4/4L60e Swap, 11 Second Daily Driver [b](SOLD)
-1970 510 Wagon: L20B swap, electronic ignition, DGV Weber, otherwise stock
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
