Spindle-Pin-Puller Loaner program
I want to say a special thanks to Dave for his help and the use of the spindle puller program. Although one side gave me fits and I broke the tool, Dave came thru with the replacement parts and I was able to remove the other side easily. I have sent the tool back as of 09/24 for someone else to use.
One thing I noticed when removed the pin with the tool was the markings inside the spindle bore. I have posted a pic which isn't very good but you will see what looks like a drag mark that was -maybe left from the original install? It is possible(but unlikely with such low miles) that this pin was changed before but the mark is NOT fresh, it is looks old. The mark starts at the edge of the bore and ends at the set bolt. I just thought it looked strange.
Got the puller back today from madkaw and its ready to send again. There are still a couple loaners out that have not been sent back yet.
The puller went out to "poortecher" this evening. Unless the other 2 loaners make it back soon I have no loaners. Gary (beandip) over at classiczcars.com has his back so there are backups if you contact him.
Dave, I'm sorry to say that I broke the tool. The heli-coiled threads that attach to the pin pulled right out and stripped the threads inside of the threaded rod. One side popped out no problem, but the other side is really frozen I guess. I thought I'd drill it out a size bigger, bottom a bolt in the hole, and re-drill and tap the center. Let me know what you'd like me to do.
Thanks,
Eric
Guest znow white
lol two in a row dave id like to use the puller as well whenever the other loaners come back IM in canada btw pm me or email mafia_neo@hotmail.com
my car is on all 4 stands the front bushings and suspension has already been done the rear is completely dismantled I will try to attempt first with out puller. I will keep you postd Thanks Hussein
err I should of posted this earleieeer o well
  • 3 weeks later...
  • 5 weeks later...
Does anyone have pictures of what this puller looks like?
Jon
Jon. If you go here I have the directions for the puller that I send with it.
http://www.v8-240z.com/Files/Datsun/Spindle-Pin-Puller/Packaged'>http://www.v8-240z.com/Files/Datsun/Spindle-Pin-Puller/Packaged Directions/
These are actual pictures of the puller I make being used
http://www.v8-240z.com/files/Datsun/Spindle-Pin-Puller/Puller How To_files/
Here are more pictures of pullers, some mine and some other designs.
Dave,
Thanks for all your help with this.
Jon
  • 4 weeks later...
Guest 240 Al
Hi Dave, I see you have a spindle pin loaner program. I'm in a bad need. I have the left side out but can't get the right out, and have my 240 apart in my garage. How long will it take to get it my way! Thank's
240 Al
Hi Dave, I see you have a spindle pin loaner program. I'm in a bad need. I have the left side out but can't get the right out, and have my 240 apart in my garage. How long will it take to get it my way! Thank's 240 Al
240 Al, I think at the moment you are 2 down on the waiting list. I have 3 of the pullers out on loan to members and and am not having much luck in getting them returned in a timely manor. I have not had a loaner ready to go out since the last one went out several months ago. I need find a way to get a speedy turn around with these pullers so others can use them.
