JMortensen
Differential / CV / LSD / HP / Torque / R160 / R180 / R200 / R230 / Diff Mount
I don't like to post in the FAQ threads but this seems like it might be appropriate.  clarkspeed posted a link to a site, about shocks, but the site also had a pretty good description of the different differential options and how they behave.
http://farnorthracing.com/tech_quaife.html  (after 175 posts, maybe it's already in here...)
clarkspeed's post - http://forums.hybridz.org/topic/69623-the-strut-thread-koni-illumina-tokico-carrera-bilstein-ground-control/page-23?do=findComment&comment=1135971
Share this post
Link to post
what I'd like to know is I have a 1980 280zx 2+2 which came with auto trans and I put sbc and th350 trans in.so I would like to know is this it has a r180 in it and want to put in r200 back in . do I need c/v joints from the r200 to install. what else and what r200 rear ends from what years,models work best.
Share this post
Link to post
Everything is shown n the two links below.  You might need something bigger than the phone you're pecking at, to read through them.
http://www.nicoclub.com/FSM/280z/1980/RA%20Rear%20axle%20and%20Suspension.pdf
http://www.nicoclub.com/FSM/280z/1980/PD%20Propeller%20Shaft%20and%20Differential.pdf
Share this post
Link to post
I have looked at this thread in the past and completely missed the part where an S13 lsd will work in the long nose R200.
If no one minds, delete me if you feel the need but I made a thread because I didn't see/comprehend the info here.
Any aftermarket S13 lsd made for an S13 open diff will fit into a long nose R200 and work with the stock 280Z stub shafts as well as the Z31T axles.
Does anyone see a problem with that statement or is it unnecessary?
I remember there being a difference with bolt size, 10mm vs 12mm in the S30/130 R200 and Z31. I can't remember which is which, though.
EDIT: Ugh, didn't realize how old that discussion was. Going to search and see if I can find it but if anyone knows off the top of their head it would be very helpful.
Edited by Pac_Man
Share this post
Link to post
