Differential / CV / LSD / HP / Torque / R160 / R180 / R200 / R230 / Diff Mount
  • Please log in to reply
179 replies to this topic
#41 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • PipPipPipPipPipPipPipPipPipPip
  • 12399 posts
  • LocationSeattle area, WA
Posted 07 November 2006 - 11:57 AM
Added info on stub axle failure, spider gear failure, and Phantom Grip LSD. I could NOT find pictures of the cross pin shaft bent and broken. If anyone has pictures of that and doesn't mind, let me know!
Jon Mortensen, owner/operator www.petdoorstore.com
#42 Guest_Mike_*
Guest_Mike_*
  • Guests
Posted 07 November 2006 - 12:56 PM
This thread isn't a "sticky" yet?!:shock: LOTS of great info here!!!!!
#43 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12399 posts
Posted 07 November 2006 - 12:59 PM
Um, yeah it is... :D
#44 alexideways
alexideways
    Member
  • Members
  • PipPipPipPipPip
  • 874 posts
  • LocationMontréal, Qc, Canada
Posted 07 November 2006 - 02:09 PM
Great, now I can just take all my notes I've started gathering and trow them away, this is infinitely clearer than what I had came up with THANK YOU, now I know what I want and need.
#45 madkaw
madkaw
    HybridZ Supporter
  • Donating Members
  • 1744 posts
  • LocationBloomington, Indiana
Posted 09 November 2006 - 11:29 AM
"AND the subaru R160 units have the same spline count and can be converted this way too... "
BJ,
do you know what years that would be . I am very interested in the easy swap to a newer suby rear and the weight saving over a r200 is something to be considered.
Jon, great right up. You sure save us a lot of questions and research. Then again , you sure cause a lot of questions and researchfor me:lol: if you know what I mean. Lot's of alternatives here , but not complaining!!!
Steve,
9/71 240z. 2.4 -.40 over, balanced. E-88 Bigger SS valves, stage 2, 6x2 header, true dual exhaust. BW t-5 , STI LSD 3.90- triple Mikunis 40mm
#46 gretchen/jason
gretchen/jason
    Member
  • Members
  • PipPipPipPip
  • 350 posts
Posted 11 November 2006 - 07:51 PM
Well i assume i have a R180 from a stock 78 280z but my diff is out of a early 80,s nissan truck for the 4.11 gears how much power will it hold up to rite now im at 340 crank hp with 360 torque crank and no problems except a clunking sound from my struts !!!
Jason
#47 gogriz91
gogriz91
    Member
  • Members
  • PipPipPipPip
  • 162 posts
  • LocationMiddle GA, for now
Posted 16 November 2006 - 01:35 PM
Well, I've got a donor R200 and the CLSD on order. What else should I replace when the diff is cracked open? Would it be prudent to media blast and powdercoat it too?
"Day/Night VFR street fighter" '73 HLS30 129806; L-28, street cam, SUs, 5-speed, Koni's, Suspension techniques springs, swaybars, R200 w/3.90 LSD, BRE front/rear spoilers, Pertronix ignition
Heavily medicated for your protection
#48 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12399 posts
Posted 16 November 2006 - 02:54 PM
Post your questions in your own thread. Lets keep this one on topic.
#49 280Z28
280Z28
    Member
  • Members
  • PipPipPipPip
  • 205 posts
Posted 29 March 2007 - 10:13 AM
So has anyone heard of [edit: someone breaking] the R230 yet? I might have the opportunity to be the first person to break it, although I'm also considering the Ford 8.8 IRS for strength. It seems the axles end up the first part to fail. Is anyone making 4340 or billet axles for the R230?
#50 Matt K
Matt K
    Member
  • Members
  • PipPipPipPip
  • 169 posts
  • LocationSouthwest (New Mexico)
Posted 29 March 2007 - 01:28 PM
Is it possible to swap in a short nose R200 from the 89+ 240SX's? I haven't seen anything as of yet...There was a guy back in Okinawa who sent his S30 up to mainland Japan to have an entire GTR rear subframe custom installed...he was running a built SR20DET with a T04Z...that sucker was awesome!
'04 G35 Sport Coupe, '78 280Z restomod, '82 ZX slicktop coupe (sold), modded '90 Mustang GT (sold), '93 240SX 600hp SR20DET (sold), '90 240SX 360 rwhp (sold), '73 Celica ST (sold), '90 Z32 TT (sold), '90 Z32 N/A (sold),'73 240Z (gave to my little brother).
#51 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12399 posts
Posted 29 March 2007 - 01:52 PM
Did you brain fart there 280Z28? R230 is in the title of the very thread you're posting to asking if anyone has ever heard of an R230. Probably wouldn't be there if we'd never heard of it, don't you think? Same thing with Matt K. Please read the whole thread before you post to it. Both of these diffs, the shortnose R200 and R230 are discussed at length right here. Can't make it any more obvious than that.
#52 280Z28
280Z28
    Member
  • Members
  • PipPipPipPip
  • 205 posts
Posted 29 March 2007 - 02:54 PM
Yes, see my edit for what I meant :lol:
#53 COZY Z COLE
COZY Z COLE
    Retired Admin.
  • Members
  • 1394 posts
Posted 29 March 2007 - 06:48 PM
Just what are you exactly planning on doing motor wise????? My blower motor, before I swapped to a R-230, was producing over 400 rwft.lbs. using my stock R-200/ u-joints with no problems. When I went to 195 AFR heads I also did the R-230 conv. just because I could, not because I was breaking parts of the stock R-200 set-up.
LARRY
Said to many times!! My uncle, brother, dad, friend, _____ has a Z just like yours..... 1975 280Z 355 SBC with WEIAND 144 PRO-STREET BLOWER, R-230 conv.
#54 z-ya
z-ya
    Member
  • Members
  • 2982 posts
  • LocationBuzzards Bay
Posted 08 May 2007 - 01:39 PM
Identify this differential. It is an R160 from a Subaru. Note the ratio! At first I thought it was an open differential as output shafts turn opposite direction when one is turned. It doesn't look like a normal open diff.
Posted Image
Posted Image
Posted Image
Posted Image
"I finally found my old blue jeans. I could tell that they was mine from the oil and the gasoline."
- ZZ Top
#55 JustinOlson
JustinOlson
    Slithering snake
  • Members
  • 1703 posts
  • LocationPortland, Oregon
Posted 02 June 2007 - 11:04 AM
Here are pictures of the OBX 240sx (R200) differential as received.
Posted Image
Posted Image
Posted Image
Posted Image
Regards,
Justin
#56 z-ya
z-ya
    Member
  • Members
  • 2982 posts
Posted 02 June 2007 - 01:09 PM
Justin,
What are you going to use for spline shafts?
- ZZ Top
#57 Omar
Omar
    Member
  • Members
  • PipPip
  • 48 posts
Posted 15 August 2007 - 03:02 PM
excelent info thanks.
justin just an FYI, i know a buddy that got that same diff and somehow broke it at a drift day. idk they have a pretty bad rep. and ive seen it first hand.
#58 marcg
marcg
    Member
  • Members
  • PipPipPip
  • 61 posts
  • LocationKingston, Canada
Posted 27 August 2007 - 12:38 PM
So is it safe to say that if I am looking for a KAAZ LSD unit for my 92 Q45 VLSD diff, I should be asking for the Z32 NA unit? I called Option Imports and they do not have a listing for the Q45 diff. Not surprised. It appears the only difference between the Q45 and the NA Z32 diff would be the gearing. Am I right or "out to lunch"? The Z32 unit would cost me $855.00 + shipping.
Let me know I need to order one soon.
Should I source out from someone else?
#59 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12399 posts
Posted 27 August 2007 - 12:42 PM
The question is which Z32's had the VLSD? If all of the NA cars did then that would be the one you should order. I'm not sure on that one though...
#60 Phantom
Phantom
    Member
  • Members
  • 2672 posts
  • LocationYakima, Washington
Posted 27 August 2007 - 01:06 PM
I thought only the one version of the Z31 in 1988 had a VLSD and that was an R200? I was unaware that any of the Z32 models had viscous LSD's?
'77 280Z with LS1/T56, '93 Z32 convertible, '05 Audi A8L, '02 Suburban LT
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
