Differential / CV / LSD / HP / Torque / R160 / R180 / R200 / R230 / Diff Mount
  • Please log in to reply
179 replies to this topic
#161 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • PipPipPipPipPipPipPipPipPipPip
  • 12411 posts
  • LocationSeattle area, WA
Posted 05 November 2012 - 09:12 PM
You'd have to have the holes in exactly the right position. Sleeves are cheaper and easier than paying a machinist to do this would be.
Jon Mortensen, owner/operator www.petdoorstore.com
#162 EF Ian
EF Ian
    Junior Member
  • Members
  • PipPipPipPip
  • 475 posts
  • LocationPortrush - Northern Ireland
Posted 06 November 2012 - 04:15 PM
Thanks, I guess the metal is pretty hard so it would be hard for even a machinist to tap the whole properly.
The sleeves don't need to be anything special do they? Any hard steel pipe cut the correct size will work fine?
#163 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12411 posts
Posted 06 November 2012 - 05:26 PM
Just get the bronze ones from mcmaster.com and save the hassle. Search and you'll find the part number.
#164 skirkland1980
skirkland1980
    Junior Member
  • Members
  • PipPipPipPipPip
  • 874 posts
  • LocationMarietta, GA
Posted 12 November 2012 - 06:23 PM
Yes they do.
So the 87-89 Z31 turbo diff is a direct replacement for the 1983 280zx turbo? I also read that the Z31 turbo cv axles are stronger. Are they a direct replacement also? Thanks
:1983 280zx turbo, L28ET, custom cam grind, 96 saab 900 intercooler w/2.50" piping, 3" mandrel bent exhaust, megasquirt II v3.57, 540cc injectors, walbro gsl392 255lph fuel pump, aeromotive regulator, -6 supply lines, custom fuel rail, MSD ignition wires, MSD 8202 coil, homemade boost controller, Garrett TC4305 turbo, 70mm throttle body, Godzilla BOV, Turbonetics wastegate, custom intake, custom turbo header, Cooling Mist H2O/meth injection, 20psi boost, all stock body, stock interior and weld draglite wheels, TH350 trans 4000 stall with B&M 'street stick' shifter and hughes trans brake, nitto nt555R drag radials, best 1/8 mile of 7.53@ 98 mph
#165 EF Ian
EF Ian
    Junior Member
  • Members
  • PipPipPipPip
  • 475 posts
Posted 22 December 2012 - 05:18 PM
I want to get a Kazz 1.5 way for my R200 (stock R200 found in my car originally - 78 260Z) (I'll be using Z31T CV shafts)
The info I can find says a LSD for the S13/S14 open will fit with the correct spline count for Z31T stub shafts. The problem is there seems to be quite a lot of variations of this lsd and I want to make sure buy one that will fit.
I believe the bottom diff on this page will fit?
http://www.limited-s...atalog/S13.html
Thing is if I look up that part number on this page it seem to be for a viscous diff
http://www.driftwork...13-s14-s15.html
Can anyone confirm which diff will fit because I'm having a hard time.
http://www.limited-s...issan200sx.html
#166 redleg
redleg
    Junior Member
  • Members
  • Pip
  • 23 posts
  • LocationFL
Posted 23 December 2012 - 05:42 AM
From what I have read in formus, If you find a r200 with the vlsd, you must have the matching cv axles for that vlsd.
If you buy a aftermarket vlsd for your r200, you may need those cv axles made for the vlsd unit.  It Maybe easier to find a clsd r200 and use the cv axles you already have. Or buy a Quaife lsd.
#167 EF Ian
EF Ian
    Junior Member
  • Members
  • PipPipPipPip
  • 475 posts
Posted 24 December 2012 - 04:52 PM
I don't want a VLSD, I want a CLSD, all the Kazz diffs are CLSD, My current diff is the stock open diff, not a VLSD unit.
I know there are KAZZ LSDS that fit my diff casing and have the correct spline count for my Z31T CV axels, I just need to somehow confirm which is the correct lsd before I buy it.
#168 EF Ian
EF Ian
    Junior Member
  • Members
  • PipPipPipPip
  • 475 posts
Posted 24 December 2012 - 04:58 PM
Will any LSD for an R200 fit my casing? If so that would mean that its only the spline count that would have to be the same?
I've heard an S13 LSD will fit, but theres many variations of the S13 lsd?
http://www.rhdjapan....ca18-sr20-58450
#169 EF Ian
EF Ian
    Junior Member
  • Members
  • PipPipPipPip
  • 475 posts
Posted 21 January 2013 - 09:13 AM
Are there any viscous halfshafts that have the same bolt pattern as the Z31T ones and that therfore I will also be able to use with my Z31T adaptors?
Reason being I want a Kazz 1.5 way lsd for my longnose R200 but unfortunatly Kazz only make 2 way replacements for the R200 open diffs, therefore for me to use a 1.5 way lsd I need to purchase a kazz 1.5 lsd for a viscous R200 unit and therefore I need the correct input shafts for whichever viscous replacement I go for. However I still need to use my Z31T cv adaptors so whichever viscous shafts I get need to have the same bolt pattern at the outboard (stub shaft) end.
#170 logr
logr
    Member
  • Members
  • PipPipPipPip
  • 196 posts
  • LocationNorth Idaho
Posted 20 May 2014 - 05:47 PM
I have looked at this thread in the past and completely missed the part where an S13 lsd will work in the long nose R200.
If no one minds, delete me if you feel the need but I made a thread because I didn't see/comprehend the info here.
Any aftermarket S13 lsd made for an S13 open diff will fit into a long nose R200 and work with the stock 280Z stub shafts as well as the Z31T axles.
Does anyone see a problem with that statement or is it unnecessary?
It's not the length of your crank that counts, it's the power of your stroke.
#171 EF Ian
EF Ian
    Junior Member
  • Members
  • PipPipPipPip
  • 475 posts
Posted 21 May 2014 - 12:26 PM
Makes sense to me
#172 jhm
jhm
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPip
  • 552 posts
  • LocationHampton, VA
Posted 04 August 2014 - 12:29 PM
Update regarding the Power Brute LSD by Precision Gear....does not appear to be available any longer for most of our common applications (R180 & R200).  Precision Gear was purchased by another company (Omni-ADA) last year, who specializes in 4x4 off-road equipment, and the LOM55E/L and the LOM59-12 are listed as discontinued models.   BUMMER!!!     :(
I apologize in advance if this info was posted elsewhere and I missed it.  Wanted to make sure it was out there so folks don't waste their time going down rabbit holes.  If I'm wrong, someone please correct me (I would LOVE to be wrong, in this case!)
#173 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12411 posts
Posted 04 August 2014 - 03:20 PM
Omix-Ada. The Power Brute hasn't been available for years, well before the purchase.
#174 jhm
jhm
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPip
  • 552 posts
Posted 04 August 2014 - 05:10 PM
Thx for the correction, JM.  The strange thing I found was that Precision Gear's website is still public (with an update of 2013), and it lists 2 units for the R180....maybe they were not keeping it current the last few years?
#175 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12411 posts
Posted 04 August 2014 - 07:17 PM
Suffice it to say WAAAAY out of date.
#176 NewZed
NewZed
    Clandestine Moderator
  • Members
  • 5195 posts
  • LocationWashington County, Oregon
Posted 25 February 2015 - 12:21 PM
I don't like to post in the FAQ threads but this seems like it might be appropriate.  clarkspeed posted a link to a site, about shocks, but the site also had a pretty good description of the different differential options and how they behave.
http://farnorthracin...ech_quaife.html  (after 175 posts, maybe it's already in here...)
clarkspeed's post - http://forums.hybrid...23#entry1135971
#177 zxcrazyv8
zxcrazyv8
    Newbie
  • Members
  • Pip
  • 4 posts
  • Locationwa
Posted 28 July 2015 - 02:03 PM
what I'd like to know is I have a 1980 280zx 2+2 which came with auto trans and I put sbc and th350 trans in.so I would like to know is this it has a r180 in it and want to put in r200 back in . do I need c/v joints from the r200 to install. what else and what r200 rear ends from what years,models work best.
#178 NewZed
NewZed
  • Members
  • 5195 posts
Posted 28 July 2015 - 02:14 PM
Everything is shown n the two links below.  You might need something bigger than the phone you're pecking at, to read through them.
http://www.nicoclub.... Suspension.pdf
http://www.nicoclub....ifferential.pdf
#179 Pac_Man
Pac_Man
    Always Here
  • Members
  • PipPipPipPip
  • 232 posts
  • LocationEverett, WA
Posted 05 August 2015 - 03:29 PM
I remember there being a difference with bolt size, 10mm vs 12mm in the S30/130 R200 and Z31. I can't remember which is which, though.
EDIT: Ugh, didn't realize how old that discussion was. Going to search and see if I can find it but if anyone knows off the top of their head it would be very helpful.
Edited by Pac_Man, 05 August 2015 - 03:31 PM.
#180 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12411 posts
Posted 05 August 2015 - 07:11 PM
Want to say they switched mid Z31. That's old recollection, but I would say around 86 maybe.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
