Adding Clutches to the CLSD R200
  • Please log in to reply
68 replies to this topic
#61 Scott_M67
Scott_M67
    Member
  • Members
  • PipPipPipPip
  • 119 posts
  • LocationGreater Seattle, WA
Posted 17 September 2010 - 12:05 PM
Hi Gary, I sent you an email looking for clutches.
Scott
#62 Savage42
Savage42
    Member
  • Members
  • PipPipPipPipPip
  • 896 posts
  • LocationSarasota, FL
Posted 17 September 2010 - 03:51 PM
Got it! I've got you covered!
Gary Savage - http://www.Savage42.com
#63 3ftyZ
3ftyZ
    Newbie
  • Members
  • Pip
  • 22 posts
  • LocationSandyEggo
Posted 17 September 2010 - 05:19 PM
Go back to the very first post in this thread and it's pretty straight forward as to what you need to do. If you want to use all 6 new clutches, then you take out the two existing ones and use all 6. If you retain the 2 OEM clutches, then just add the 4 clutches in the positions in this picture. This is how it's been done with the 100+ units that people have done over the years and not a single problem to date. (that I'm am aware of) Hope this helps.
Savage. Thanks again for your help.
So, the clutches and the plates are all metal, is this correct? There is no 'friction' material (like a clutch in a transmission) on these LSD units? Sorry for the 'dumb' questions, just a noob looking for help.
Thanks!
#64 Scott_M67
Scott_M67
    Member
  • Members
  • PipPipPipPip
  • 119 posts
Posted 17 September 2010 - 05:43 PM
It is not uncommon to use solid steel for high performance clutches in differentials. The friction material found in some OEM and aftermarket disks just burns up or comes apart in these applications, that why solid steel is used.
#65 Gollum
Gollum
    Tree Killer
  • Members
  • PipPipPipPipPipPipPip
  • 2922 posts
  • LocationVacaville, CA
Posted 20 January 2011 - 11:48 AM
Also remember that these clutches are working in a wet oiled environment. Your clutch on the flywheel is a dry environment. The clutch material that contacts the flywheel is not so different than brake pad material, and we all know that grease on your rotors is BAD for braking. Same thing in a diff. You have to take the oil into account. And in this environment, metal on metal for a clutch won't wear the same as it would dry, and will have a very different break away characteristic compared to dry.
All that being said, I'm reading this reading up on what my options are for converting to a LSD down the road. Does anyone know what the clutch/spacer pack looks like in the power brute carrier? Some seem to say it's a lot like the Nissan unit in the Z31, but I can't find info on what the break away levels are like from as-ordered and if the same clutches could be used, or how many clutches it has in it.
'75 280Z, L28ET, Street going rat rod
http://forums.hybrid...ms-dd-l28et-75/
#66 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • PipPipPipPipPipPipPipPipPipPip
  • 12432 posts
  • LocationSeattle area, WA
Posted 20 January 2011 - 01:01 PM
There is a thread where bjhines and I were arguing over this, because I had the Z31 diff apart and he had the Power Brute apart. We were both sure that we were right (we were) and the other was wrong (we weren't). You can look and find that thread if you want, but the basic jist is this (maybe bjhines will see this and fill in any gaps in my memory). The Power Brute has more clutches. I think it has more clutches than a Z31 with clutches added. It has more aggressive ramps on the cross pins, so it puts more pressure on the clutch stack. It has thrust washers on the gears, where the Z31 doesn't. I think that's about it. So basically, it's built stronger and more aggressive in every respect. To the Z31 LSD's credit though, apart from people who strip off the clutches, you don't hear too many people complaining about wheel spin with them.
Jon Mortensen, owner/operator www.petdoorstore.com
#67 bjhines
bjhines
    HybridZ Supporter
  • Members
  • 1905 posts
  • LocationCary, NC
Posted 20 January 2011 - 07:19 PM
The LOM-59 unit to fit the R-200s was completely different than the factory unit.
6 disks per side for 12 total
low ramp angles
Forged cross instead of single pin
Zero thrust side gears for constant internal gear lash
very low preload for better turn in
overall larger and stronger components
Posted Image
Posted Image
Posted Image
Posted Image
Definitely on the Dark Side
#68 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12432 posts
Posted 20 January 2011 - 09:12 PM
The Z31 has a forged cross with 4 pinions and a factory preload of about 15 lbs. Not sure what is larger in the PB either. I think they're the same size clutches and all that, just different ramp angles and thrust washers and more clutches.
#69 Fairlady240Z
Fairlady240Z
    Moving Up
  • Members
  • PipPip
  • 25 posts
  • Locationpittsburgh PA
Posted 16 April 2013 - 11:23 AM
Great found this thread again bought the clutch packs from Savage now have info for rebuild thank you
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
