* * * * - 1 votes
Sign in if you own an s130!
  • Please log in to reply
1325 replies to this topic
#41 phil280zxt
phil280zxt
    Member
  • Members
  • PipPipPipPip
  • 137 posts
  • LocationConnecticut
Posted 01 July 2007 - 09:16 AM
I owned an 80 280zx back in 82-84. Sold it when the family started arriving. Got the Z bug again in 2001 and bought my current 81 280zxt. Same silver over blue color as my first, but this one has t-tops and its a turbo!! I've slowly modified her from auto to 5-speed swap the first year to an intercooler last summer. Now I need to address the rust issues.
Posted Image
Posted Image
1981 280zxt
5-speed conversion/3.9 R200/Eibach springs/Tokico struts/Energy Suspension bushings/K&N CAI/Innovate WB/Cusco Strut Bar/Greddy B Spec II boost control/Jeffp 3 in mandrel bent SS exhaust/Magnaflow/Spearco Intercooler/HKS SSQV BOV/Z31 MAF/ECU conversion/currently 12 PSI
#42 cpt jack
cpt jack
    Member
  • Members
  • PipPipPipPip
  • 260 posts
  • LocationWahiawa Hawaii
Posted 01 July 2007 - 12:45 PM
I use generic coils the are in the 300 range and stiff as hell!
On the 40 tires and no rubber in the front strut assembly to be found all i can say from a little test ride ..
it is blood pissing stiff!
Given the struts are on their heaviest setting, also i use msa sway bars and adjustable end links ( one poly rubber in there)
do you happen to have a site mate to where you got them? easy install?
SGT of Marines, and damn proud of it!
#43 slownrusty
slownrusty
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPipPipPip
  • 2261 posts
  • LocationHouston
Posted 03 July 2007 - 07:40 PM
Great cars guys....
Here is mine:
Posted Image
Posted Image
Posted Image
Suspension:
1) Custom made coilovers front and rear with Tokico ProDraG imported from Japan
2) Suspension Techniques sway bars front and rear
3) Poly-urethane bushings front and rear
4) Every piece replaced....sand blasted and painted
Engine:
Stroker 3.0L LD Crank
240Z 9mm rods
JE pistons - 8.3:1 compression
Ceramic coated piston tops and skirts
Diamond Like Coatings on Wrist Pins
WebCams Turbo Grind Cam
Whitehead Performance extensively ported and polished head
Speed Shop Thagard T3T4 Turbo Stage 5 wheel - 360degree thrust bearings
Corky Bell Custom Made Intercooler - 2.5" inlet and outlet
ARP Head Studs
ARP studded bottom end
ARP rod bolts
Arizona Z Car flywheel
Clutchmasters Clutch
Flexalite twin 10" Electric Fans with manual overide and thermostat
Arizona Z car Radiator
Haltech E6X
JSK Fuel Rail
550cc Injectors
Walbro 255lp/h Fuel Pump
Aeromotive FPR
Lots of braided lines and polished parts
SFP custom made Exhaust Manifold
JamieT custom made intake manifold with 67mm Throttle Body
Tial 38mm wastegate
HKS SSQ BOV
3" Jeff Priddy Down Pipe
3" exhaust with Burns Stailness Muffler
Autometer Boost, Oil Temp, Oil Pressure, Water Temp and AEM AFR Gauges
Shooting for 450+ whp sooon.
Yasin
Ole skool "wouldn't have it any other way"
#44 roger280zx
roger280zx
    Member
  • Members
  • PipPipPipPipPip
  • 565 posts
  • LocationMonroe, GA
Posted 03 July 2007 - 09:31 PM
Nothing special, just a wrecked 1983 black, t-top, non turbo with "cold air intake" 60mm tb, and a muffler shop special 2.5" cat back with a leaky head gasket. Oh and about 100lbs taken out of her... that helps.
#45 bschiltz
bschiltz
    170 oz, Malt liquor
  • Donating Members
  • PipPipPipPip
  • 414 posts
  • LocationLincoln, NE
Posted 04 July 2007 - 09:16 AM
Here's mine
Posted Image
Posted ImageStill working the kinks out of her.
1979 280ZX with '86 305 and 700R4
#46 cpt jack
cpt jack
    Member
  • Members
  • PipPipPipPip
  • 260 posts
Posted 04 July 2007 - 10:51 AM
Here's mine
Posted Image
is the 305 a smaller v-8? and well anyways do u like the motor? i been thinkin of goin with a 350...
#47 bschiltz
bschiltz
    170 oz, Malt liquor
  • Donating Members
  • PipPipPipPip
  • 414 posts
Posted 04 July 2007 - 02:26 PM
smaller displacement but the same external dimensions as a 350. I haven't got to drive the car too much, but it seems to have a fair amount of bottom end torque.
#48 SoCal-s130
SoCal-s130
    Member
  • Members
  • PipPipPipPip
  • 132 posts
  • LocationCalifornia
Posted 04 July 2007 - 03:59 PM
Posted Image
Posted Image
And unfortunately now... Except now it has a straight black fender and light bucket. Hopefully will look how it did soon.
Posted Image
#49 KTM-EXC
KTM-EXC
    Member
  • Members
  • PipPipPipPip
  • 260 posts
Posted 04 July 2007 - 04:12 PM
^^^sorry to hear that, hope you get your car back to were it was. Iv always liked your ZX
Some people wanted to see how my car looked with the BRE spoiler so heres some pictures. Please excuse the wheels, im in the middle of either getting new wheels or spacers for my Advans
Posted Image
Posted Image
Posted Image
#50 SoCal-s130
SoCal-s130
    Member
  • Members
  • PipPipPipPip
  • 132 posts
Posted 04 July 2007 - 04:47 PM
What suspension is your car sitting on, KTM?
#51 Sean 83ZXT
Sean 83ZXT
    Member
  • Members
  • PipPipPipPip
  • 212 posts
  • LocationFair Oaks, CA
Posted 04 July 2007 - 04:58 PM
KTM-EXC - Is that just a BRE spoiler for the 240Z installed on a 280ZX or is it modified somehow?
#52 KTM-EXC
KTM-EXC
    Member
  • Members
  • PipPipPipPip
  • 260 posts
Posted 04 July 2007 - 05:01 PM
Im just running tockicko springs/dampers, I think its only a 1" drop
and yes thats a regular 240z BRE spoiler, its a direct bolt on
#53 SoCal-s130
SoCal-s130
    Member
  • Members
  • PipPipPipPip
  • 132 posts
Posted 04 July 2007 - 05:14 PM
Dang mine was only a 1" inch drop but yours looks way lower =/
#54 award280
award280
    Member
  • Members
  • PipPipPip
  • 65 posts
  • LocationAustin TX
Posted 05 July 2007 - 04:46 AM
I've had my '83 for a little ove ten years now. T-top, 5 spd, NA coupe. I finally started really tearing into it at 274k miles. As she sits now:
Flat top pistons with N42 head.
Balanced internals, ARP Studs and Rod bolts.
Z31 ECU with Nistune. (Still wiring)
Much more stuff, but I'm too lazy at the moment.
'83 280ZX (in pieces)
'82 280ZXT
#55 mikeatrpi
mikeatrpi
    Member
  • Members
  • PipPipPipPip
  • 365 posts
  • LocationNY
Posted 06 July 2007 - 04:21 PM
I think I'm in love KTM! Very tastefully done! I like the blacked out lighting and the drop- just makes the dark colored car look even more sleek. What are the window stickers? I'd buy a hybrid z sticker if it wasn't 2 square feet in size!
82 280zx NA - T conversion MSnS-e Photo Log - Build Thread
#56 280zxcoastie
280zxcoastie
    Junior Member
  • Members
  • Pip
  • 6 posts
Posted 06 July 2007 - 09:03 PM
Here is mine about a couple months ago or so
Posted Image
#57 KTM-EXC
KTM-EXC
    Member
  • Members
  • PipPipPipPip
  • 260 posts
Posted 07 July 2007 - 04:47 AM
Thanks alot, its a PeteZ and Zdriver sticker. Dont usually like stickers on my car but there not to big
#58 KTM-EXC
KTM-EXC
    Member
  • Members
  • PipPipPipPip
  • 260 posts
Posted 07 July 2007 - 04:49 AM
Posted Image
Looks good, I think if it was lowered a little it would be one nice looking car.
#59 slownrusty
slownrusty
    HybridZ Supporter
  • Donating Members
  • 2261 posts
  • LocationHouston
Posted 07 July 2007 - 05:43 AM
KTM - Your car is truly killa....I love it....! Two thumbs up from the Slow 'N' Rusty Camp!
Yasin
#60 KTM-EXC
KTM-EXC
    Member
  • Members
  • PipPipPipPip
  • 260 posts
Posted 07 July 2007 - 06:01 AM
Yasin
that means a lot coming from you Yasin.. thanks!
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
