$3k a good deal? (56k NO WAY)
I've been searching for a local project car that my granddad and I can use for a project and found this. After meeting the guy and talking to him, we worked out that I could get it for $3k out of pocket.
The skinny, car is mostly taken apart. The engine is BRAND NEW, zero miles with build receipts and such. Some goes for the manual tranny. The drivetrain is halfway back in the car. I think the car itself has about 130k on it.
New floorpans
New framerails
100% Undercoated
New Gas Tank
Pro shaved handles
shaved key holes
molded headlight bezels
shaved roof rails
"new" paint maybe a year "old" but hasn't been driven. Sitting in storage since
full energy suspension kit, installed
aftermarket suspension....tokico and something else
bigger brakes in the front (Some sort of 4x4 swap)
New Corbeau reclining race seats with model specific mounting brackets
5 point harnesses
roll cage
Newly installed carpet, headliner, rear interior
LOTS of Dynomat
Expanding foam sprayed into some parts of the car. (A bit confused on this)
new weatherstripping
I'm sure there's stuff I'm forgetting and a lot of stuff that I don't understand but that should cover it for now. He said he never bought new door panels and a few other odds and ends...but the car is nearly 100% complete and most of the stuff is still very new or even still packaged.
I'm already pretty sure of what I should do, but I thought I'd post to make sure that I didn't miss something obvious.
PICS:
is it me or are those bushing in the lca the stock ones?
And i don't really like the white faced gauge overlays but that is personal
anyhow .. 3 k is allot of money but allot of the shitty work has been done, dont forget allot still has to be done !
If you like the paint then get it! it looks like the hood needs to wet-sanded still?
That gas filler door is pretty slick.
Thankfully the air dam is not molded in. I have only seen problems with molded in airdams.
Something looks funky near the engine crossmember on the frame rails. Rivets...eek.
Thanks guys. The Rivets on the framerails were his idea of "reinforcement". Those rivets supplement tack welds holding on long strips of steel that run the length of the framerail.
The paint is slick in most parts, but here and there is could use some sanding for sure. I'm not 100% on the color, but I'm more concerned with the car being a straight platform to start with. Paint can always bee changed later. I'd hate to let this one slip by me only to by another project car and spend years and $$$ just to get it to the point that this one is at.
Hang on here. I agree the car looks sweet, but, Doesn't this look a little odd considering the "detail" he put into the underbody...
And not to mention, I see poor coverage on the floor boards and frame rails. Looks like surface rust accumulating under that underbody coating here...
The car is beautiful, but I'm going to call BS.
