OBX vs Quaife (with pixors)
  • Please log in to reply
216 replies to this topic
#201 Xnke
Xnke
    Member
  • Members
  • PipPipPipPipPipPipPip
  • 2005 posts
  • LocationBowling Green KY
Posted 16 February 2014 - 08:08 AM
The usual sources. I bought from RacingPartsDepot.com.
#202 AlienJedi
AlienJedi
    Junior Member
  • Members
  • Pip
  • 20 posts
  • LocationPhiladelphia
Posted 16 May 2014 - 06:53 AM
Ordered an OBX unit a week ago and received the new curvy version as well.
#203 HowlerMonkey
HowlerMonkey
    Member
  • Members
  • 1385 posts
  • LocationWest Palm Beach
Posted 17 May 2014 - 04:09 PM
I'm curious about the offering from racingpartdepot in that they have 4 different links for the same application.
Any ideas if they are all the same part?
#204 AlienJedi
AlienJedi
    Junior Member
  • Members
  • Pip
  • 20 posts
Posted 19 May 2014 - 01:00 PM
I ordered this one:
http://www.ssaccesso...-OBX-LSD/Detail
Looks like the same supplier as racingpartdepot:
http://www.ssaccesso...late/about/Page
http://www.racingpar...late/about/Page
So you can use the link I provided and know you will at least receive what I have...who knows if it is right :).
#205 Larryz 260
Larryz 260
    Junior Member
  • Members
  • PipPip
  • 39 posts
  • LocationFresno Ca.
Posted 06 September 2014 - 02:30 PM
where are you guys getting these from, does someone have a part #   thanks
#206 Saddler
Saddler
    Newbie
  • Members
  • Pip
  • 2 posts
  • LocationVancouver, Canada
Posted 31 December 2014 - 05:26 PM
Hello, new to the forum, and Z's in general. I bought a '78 280Z a few months ago and am slowly collecting parts for when it warms up in the spring. On my parts list is an LSD. I am swinging towards an OBX but I stumbled across Traction Concepts http://www.tractionc...p/tcxda5327.htm On eBay. Has anyone heard of them? All my searches turn up empty. They come in under the OBX price.
I apologize if this isn't the right thread.
#207 NewZed
NewZed
    Clandestine Moderator
  • Members
  • PipPipPipPipPipPipPipPip
  • 5359 posts
  • LocationWashington County, Oregon
Posted 31 December 2014 - 06:31 PM
Search Phantom Grip.  Looks like a knock-off or rebranding of the same parts.
#208 Sideways
Sideways
    Member
  • Members
  • PipPipPipPip
  • 402 posts
  • LocationAUSTRALIA
Posted 02 January 2015 - 03:11 PM
Next to the description tab is a "technical specs".  Clicking it gives you no technical specs, but instead is just them quoting a review.  The opening of that review? "I just wanted to drop in and give my impressions on the Phantom Grip I recently installed..."
So take of that what you will.  I think what annoys me the most is theyre calling it a 2way lsd.
#209 Dan H
Dan H
    Newbie
  • Members
  • Pip
  • 6 posts
  • LocationWashington .. Ridgefield
Posted 28 May 2015 - 03:36 PM
has anyone ran a 450hp or so v8 with this OBX rebuilt like you guys are doing ? ... it would be nice to make this work with my roller 350....for the $$
#210 grannyknot
grannyknot
    Always Here
  • Members
  • PipPipPipPip
  • 218 posts
  • LocationOntario
Posted 10 July 2015 - 02:54 PM
Just got my OBX from racingparstdepot for $405. Nice and clean in that factory.
The gears were reversed so flipped them, only 9 of the 11 bolts had loctite on them.
Installed Rich Bryant's fix kit.
#211 mtnickel
mtnickel
    Member
  • Donating Members
  • PipPipPipPip
  • 285 posts
  • LocationSurrey, BC, CANADA
Posted 10 July 2015 - 10:08 PM
For those who put in the OBX unit, did you measure the runout of the ring gear surface when installed? If so, what was your tolerance?
I picked up an old stock japan made Helical from a company called Xebec. I had about .0023" runout of the ring gear face, and about .0018" radial runout.
I noticed as well I only have 8 gears in mine instead of the 12 in the OBX. I also don't have any preload washers on my unit.
Just wondering if my time trying to get a machine shop to true it is worth the effort and if I should just grab an OBX instead and be done with it.
#212 rbryant
rbryant
    Junior Member
  • Members
  • Pip
  • 14 posts
Posted 16 November 2015 - 09:07 AM
Most of the recent orders for my kit have been the newer version of the LSD over the past couple of months.
The new one with the Taper/cone/curvy shape should be superior to the old version.
My customers have reported 50mm long bolts (shank length without the head) and the ones pictured in this thread also look like 50mm to me based on the threaded length.  The 40mm is probably a typo.
This unit should be superior and should solve the center retainer issues that required the larger center washers to hold everything together in my kit.
I still highly recommend replacing the bolts and washers but this is good progress from OBX.
-Rich
http://rbryant.frees...obx_washers.htm
#213 helghast7
helghast7
    Always Here
  • Members
  • PipPipPipPip
  • 170 posts
  • Locationnew jersey
Posted 16 November 2015 - 04:57 PM
Is there an updated link or location on where to buy the correct obx unit? All the links seem to be broken.
#214 htownz
htownz
    Junior Member
  • Members
  • Pip
  • 6 posts
  • LocationHouston, Texas
Posted 22 January 2016 - 10:18 AM
Hi Guys,
I have installed the early style OBX LSD in a 3.90 r200 long nose with Rich Bryant's bolts and washers.
I am using early style u joint shafts and can not figure out how to get the flanges to "clip" in.
The flanges do not have clips and when I tried adding clips they were to big.
Do I need to removed the internal clips from the old carrier?
Troy
#215 NewZed
NewZed
  • Members
  • 5359 posts
Posted 22 January 2016 - 11:22 AM
Some people buy new clips, some re-use the old ones.  They install inside the diff, not on the axles.  Better read this thread from the beginning, there are some important posts about getting the parts right so that the clip grooves are the right distance in from the seals.  So the axles ride in the correct place.  Can't remember where, back in the #80-140 range of posts, maybe.
#216 CRAracer05
CRAracer05
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • Locationohio
Posted 27 January 2016 - 08:07 PM
Where are you guys buying your OBX LSD's at now a days?
1976 280Z - N42/N42, flap top pistons, Weber 45 DCOE, 280zx 5-speed, ZG flares, Z432 Spoiler, build in progress, rest to be determined.
#217 78-280Z
78-280Z
    Moving Up
  • Members
  • PipPip
  • 29 posts
  • LocationDetroit
Posted 12 May 2016 - 08:48 AM
Same as above ^^^ I am looking for an OBX unit but can't seem to find one anywhere.
1978 Datsun 280Z 2+2
Southeast Michigan
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
