Reaction Disk pictures and walkthrough
  • Please log in to reply
32 replies to this topic
#21 LoneStarS30Z
LoneStarS30Z
    Junior Member
  • Members
  • PipPipPipPip
  • 301 posts
  • LocationDallas ---> Okinawa
Posted 04 April 2010 - 02:29 PM
What method did you guys try to get your disks out? I took my booster off and saw the disk clunking around but it was between the big spring and the housing and was nearly impossible to grab no matter how much shaking I did.
Posted Image
#22 turbobluestreak
turbobluestreak
    Member
  • Members
  • PipPipPipPip
  • 435 posts
  • LocationDayton Ohio
Posted 05 April 2010 - 06:25 PM
After a lot of trying to pull it out by hand or with other tools, I shook it and I got lucky when it fell out. My zed brakes like a new car again :)
tbs
Blue & Silver 81 zxt, 88 ECCS
Z32 mas,420cc injectors, 1mm HKS HG
ported exhaust manifold, cable throttle linkage
t3/t4e 12psi , 3inch exhaust, K&N,
ACT clutch, 240sx t/b, 1G DSM BOV
Custom Intake
Ported and Polished N42
Tan 88-89 conquest seats
Sperco IC 18.5x6x3.5
2.5 IC pipes
Suspension work done
Nistune!!! Zeitronix Wideband
240sx transmission
IN THE WORKS:
95 Maxima Alternator
CFD Ported P90 head
Z32 front brakes
#23 LoneStarS30Z
LoneStarS30Z
    Junior Member
  • Members
  • PipPipPipPip
  • 301 posts
Posted 05 April 2010 - 11:51 PM
Lucky. I could not for the life of me get anywhere close to it, much less see it. I would spot it for a split second then lose it again.
I hate to admit it, but eventually I said to hell with it. I epoxied a 2 quarters together with a nickel in between them and attached them to the plunger and called it a day lol.
I will take another whack at it this weekend if the car doesn't need anymore immediate work.
Posted Image
#24 BunnySlippers
BunnySlippers
    Member
  • Members
  • PipPipPip
  • 56 posts
Posted 06 December 2010 - 11:55 PM
I'll have to take a look at mine soon, I've never been happy with the feel of the stock brakes..
75 280Z - She lives!!!!
88 300ZX - Collecting parts to rebuild.
06 Kawasaki ZX6R - :)
#25 chunk
chunk
    Junior Member
  • Members
  • Pip
  • 15 posts
Posted 01 January 2011 - 12:46 AM
Since my 78 280z is basically the oldest vehicle I have ever driven, I never thought much of the crappy brakes. Plus I only drove the car a few times before it was gutted for a JTR style chevy conversion.
While cleaning up the brake booster I heard the disc rattling around inside. I shook it out instead of trying to open up the brake booster. It didn't take long for that thing to fall out. I roughed up the metal and the rubber a little bit and super glued the pieces together.
Good to know the brakes wont be so crappy after adding a few horses.
#26 Pharaohabq
Pharaohabq
    Member
  • Members
  • PipPipPipPipPipPip
  • 1931 posts
  • LocationAlbuquerque, NM
Posted 14 April 2011 - 07:18 AM
Why isn't this a sticky yet?
#27 beermanpete
beermanpete
    Junior Member
  • Members
  • PipPipPipPipPip
  • 633 posts
  • LocationNorthridge, CA
Posted 18 September 2011 - 06:05 PM
Thank you for the help!! It is very much appreciated.
I got baptized in the reaction disk this weekend. I did notice that most of the posts here say to glue the disk in. I read the FSM and they say to use grease. I used grease and it works well so far. Should be good for another 20 years.
Thanks again for the assistance.
#28 bacarl
bacarl
    Newbie
  • Members
  • Pip
  • 4 posts
  • LocationMichigan
Posted 18 September 2015 - 01:23 PM
Bringing back this excellent thread...
Does the booster need to come off in order to remove the push rod assembly and check for the reaction disc? Even though blue72's was off the car, that doesn't seem like a necessary step from looking at the pics, correct? Granted, if the reaction disc is missing I suspect the booster has to come off to shake it out of there.
Also does removing the push rod tend to tear up that seal? I searched MSA and googled the internets at large but didn't come up with a replacement. Are seals typically reusable after pulling them out of the booster?
Brian
73 240Z HLS30-151534
#29 beermanpete
beermanpete
    Junior Member
  • Members
  • PipPipPipPipPip
  • 633 posts
Posted 18 September 2015 - 03:26 PM
I successfully reused the seal. With due care and some luck you should be able to reuse the existing seal as well.
#30 blue72
blue72
    I gotts-da 72 disk reaction blues...
  • Members
  • PipPipPipPipPip
  • 662 posts
  • LocationSouthern Utah
Posted 02 October 2015 - 08:24 AM
I never had any problem with the seal either.  It is pretty tough rubber.  With some kind of homemade creativity you might be able to fish the disk out of the booster without taking it off the firewall.
'72 240Z - F54, P79, '78 5 Speed, 3.9 R200
'70 510 - L16, SSS Carbs, BW Auto
'70 Chevy Suburban - TBI 454, 4L80-E
#31 Kamaka Z
Kamaka Z
    Moving Up
  • Members
  • PipPip
  • 42 posts
  • LocationOmaha ne.
Posted 29 November 2015 - 06:41 PM
would i need to adjust the pushrod if i am going from a 77 280z MC to a 280ZX MC or is it adjusted only if going from a 240Z MC to a 280ZX MC.
#32 torynich
torynich
    Member
  • Members
  • PipPipPip
  • 52 posts
  • LocationDelta Colorado
Posted 01 April 2017 - 03:52 PM
I tried to send blue72 a PM but got a message that blue72 is not able to receive any messages. None of the pics are loading up for me, is there any way to get them restored for this thread?
#33 blue72
blue72
  • Members
  • PipPipPipPipPip
  • 662 posts
Posted 08 April 2017 - 05:51 PM
Sorry about that, I just barely got new hosting and had to point the nameservers to the right place. I'm working on making sure everything is back up across the board. Looks like I still have to delete a bunch of old PMs though to make sure messages can get to me once more.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
