Evos 9sec 2jz build - 9's, 8's, and 7's done going for 6 sec pass now!
Went back to the shop today and I spent few hours working on my downpipe. One day when I really need someone to give me hand with fitting and marking piping I get "stuck" alone well at least it was nice to have whole shop to myself. Since whole shop was full of cars I was not able to use any of the lifts so I had to use good ol jackstands method. This is how the day started.
I just cant get enough of this view!
Then I stared working on the downpipe
Even though it looks like there is alot of space putting 4" pipe is not really that much fun
I am not happy with end result so I am getting rid of the last 90deg bend. Then I am going to take about two inches of that 45deg bend and that is where v-band flange will be installed to seperate downpipe from the exhaust. There is just not enough space to tuck in 4" exhaust with v-band clamp under the car.
Thats about it for this weekend I should be able to do some more work on it fallowing week during my lunch hour.
Yesterday was just another long day. I got home from shop around 11:30pm just freaking exhausted honestly I really cant wait to have my own garage so I can do this on my own time instead of doing it when I can barely stay awake. Ok enough of whining here are some pictures from last night.
Some I/C piping action (we used aluminum 3" scrap piping because it pretty much cost me nothing).
Passenger side starting point
Saturday Drew is going to weld it all together and when that is done safety wire will be added to prevent pipes from coming loose. Since cold side piping is so short it would look very awkward to put Tial BOV on there so instead of that it will get mounted right on the I/C endtank under outlet pipe. More updates coming this weekend.
I am really not feeling like typing much tonight so here are some pictures of what was done today.
Intercooler piping welded
Turbo outlet all done and cooling down
Tial Bov flange
Welded together then drilled out and ported (no pictures of inside at the moment)
Piping back in the car
Notice lower intercooler brackets well they got redone too I was just not really happy with them so they got replaced with 1" square tubing
Limited edition Tial green Bov : )
New intercooler brackets on the bottom
From the front
And one last shot for the night
Now that intercooler is finalized I started working on my radiator setup. We had two spare radiator cores from our time attack EvoX so I tried test fitting it and what do you know its perfect fit : ). Now all I need is to bribe Cory (one of our train operators) to draw me some nice endtanks and we are all set.
Guys meet Cory only thing you need to know about him is that he is just one badass dude
It took him whole 10min to get done lol
Core is two row which is more than enough for my setup
Cory put order through today so endtank parts should be here in week or so.
Well cant forget to pay the man
Well I really enjoyed my visit to Alabama for the holidays and taking break from Z was even better : ). Last night I was really tired so I really didn't feel like sticking around for long and in turn not much was done lol. Here are few pictures of what was accomplished.
Nice and comfortable in corner of the fab shop
Drew building upper intercooler bracket
I had to shorten downpipe by good amount so that massive v-band clamp would clear everything and this is final version.
Today was one of those days... just way to tired to get out of the bed let alone go to the shop and work on the Z but when you dont have your own garage and your personal project car is taking shop space well you dont have much choice no lazy weekends for me. Drew was nice enough to come in and give me hand with some welding so between two of us (neither one wanted to be here today lol) we got few small things done. Here is what we were working on.
Drew welding on intercooler mounts
Here you can see vibrant vaccum reservoir mounted on the bottom of the intake manifold
Time has finally come to get downpipe welded and she came out awesome!
Downpipe mounted on the car with wastegate pipe mocked up
Then we started working on throttle body cable I had old lokar (I think) cable from my old L28 setup so we ended reusing it for new setup but few things had to be changed around.
Pedal had to be bent 45deg to the right so that cable would not bind up against intake manifold (bad angle coming through firewall).
Once everything is done all the holes on the firewall will get filled in and minimized including this one
Take one hammer
+ Torch
= no cutting and welding : )
Tabs for the linkage brackets
Thats where was left off for today more updates coming later next week.
Wow long day at the shop yesterday. Between Drew, Chris, and me alot of custom fabrication got done and written of the list. Since it was the last day that I could keep my car at the shop (full of customers cars) I got there right about 9am by 6pm that night Z was done for the year and on its way to storage facility. Here are pictures of what we got done.
Radiator end tank parts with -16an weld on fittings
Drew putting radiator together
Throttle body cable brackets
Pedal needs little more work to line up perfect
Then the motor came out (again lol)
New transmission support
While Drew and me were bussy with our stuff Chris was rocking out with this awesome removable parachute setup.
That bend in the bark looks like its off just little bit but it really isnt its perfectly centered our trunks curves are not symetrical as they might look.
Chris machining down bar that slides through the body for better fitment
More support from the side
THE BLAIR WITCH PROJECT (yep we found their hiding place its in my damn trunk lol)
Here is the best part everything can come out by talking out 4 allen head bolts!
Done with the chassy for the year and she is off to the storage
Now I can focus on some small parts for the engine and little random fabrication projects on the engine itself. I hope that you guys are enjoying fallowing my project as much as I am enjoying working on it.
Since holidays are around the corner I decided that I am done with Z for rest of the year. I could really use some time off and combined with few days off the work should do the job! Here is the last update for this year.
New bolt for the oil filter housing that will be used for turbo oil feed (rethreaded for 1/8 npt)
Old one
New one
So few weeks ago I asked Cory for draw me very simple plate for coil on plug setup. One thing with engineers is that there is no such thing as SIMPLE lol. His idea is to actually draw complete billet plate that replaces both factory covers with coils integrated into it. Cory is using our new portable CMM arm (coordinate measurement machine). Romer portable CMM allows him to digitally plot any given area he is working with. By taking the arm and touching key points on the valve cover he can digitally recreate the entire valve cover in CAD software. The end result is a product that fits like stock but with much better appearance.
Corys starting with blank sheet
Starting with four dots
  • 1 month later...
Uhh update time I guess...lol I have spent most of my free time playing xbox live for like past month nothing better than relaxing in bed playing call of duty on 50inch flat screen : ). I did get to do few things but call me lazy I just dont feel like updating 100 pics so I will start off with few of external wastegate getting fitted on exhaust manifold. More coming up in fallowing weeks.
Wastegate getting fitted from beginning to the end
Trimmed for perfect fit
Pretty much done
All thats left now is to port runners some and to get head flange decked since she got warpped from runners being welded in one single night.
Next on the list are oil feed/return lines and here are some pictures of how that is going so far (quality of few pictures is not that good).
Diry, used, and abused... lol
I am going to upgrade rod bolts with some arp's before she gets put back together
Factory casting for oil return which I belive is same as twin turbo motor but its just not drilled and tapped
That can be fixed : )
-8 weld on fitting
-8 oil return line with goodridge heat sleeve
Before shrink tube
Afther
I am going to get bracket welded on turbo compressor outlet to keep line little more away from #1 runner just to be safe
-4 fittings for oil feed (journal bearing gt42)
One crazy Polish mechanic coming right up!!! My buddy Danny snuck in for this one lol.
Since 2jz seems to have alot of things that I wont be using I had Cory draw me few block off plates and we wanted to test them for fittment before order was sent out. Here are two of the "plates" getting fitted to verify clearance.
Egr system
There are few more but pictures came out really bad so I wont post those until real pieces came in. Next pictures are of the stock coolant inlet and outlet on the engine.
Here you can see both of them and orientation of the lower one (which I ended flipping around thats coming up).
-16 fittings welded on
That nipple is not needed for anything so off it goes
Back on the engine
I flipped lower elbow 180deg so now it gives me better clearance and making lower radiator hose will be very simple.
While ago I talked about adding another tab between throttle body brackets so that cable would not be hanging down its little things like that that really bother me so that will not be a problem.
Today was one of those days...nah just kidding it was really awesome day! Made some great progress since there were three of us working on the Z at the same time! On with the pictures.
I never got chance to show off what our awesome bead roller can do so here is how my piping looks like bead rolled
Intercooler and piping back in the car
Guess what goes there lol (nozzle is about 6-7" from throttle blade i belive)
Since fuel rails for 2jzge engines are over $250 I decided that I will spend $20-30 and see how far I can take my stock one (or whats left of the stock rail lol)
-10 feed and -8 return weld on fittings
Fpr removed I wil get Cory to draw me block off plate with o-ring for it
This is original fuel feed entry which I ended drilling out past -8 hole just trying to optimize what I got. I will use that port for fuel return.
I ended cutting out end of the fuel rail and drilling it out to accept -10 fitting
This fuel rail is so large on the outside that I had to problem drilling it through past opening of -10 hole so now I just need to get foot long drill bit and then I can drill through whole length of the fuel rail really making her support some serious fuel flow!
-10 of the left -8 on the right
For return line I am going with 180deg fitting to put me in right directionand to clear intake plenum including t/b cable (going with black fittings this one is just for test fitment)
For feed line I am also going to use 180deg fitting with fuel line going right above fuel rail where fpr used to be.
Drew welding
Nos bung
Iat bung
Thats it for today more coming up over fallowing week.
Here are some more progress pictures as promised.
Compressor housing off for welding of the turbo oil return line "support" bracket (to keep line away from #1 runner)
Now I can just install clamp around line and that will keep it nice and safe from excessive heat
Dump tube
Almost there
Support bracket for dump tube to prevent vibration and cracking since its made out of thin wall stainless steel
Thats all mocked up now next step is welding that bad boy together.
Since I am using thick wall ss with 1/2 header flange I am not worried about supporting turbo from the bottom but however side to side support from vibration and engine movement is whole another story. Here is nice and quick fix for that.
Two unused studs coming out of the head just happen to be in perfect location for support bracket
Just tacked together
Once it gets welded it should turn out pretty nice with some amazing color change.
