Mercedes Benz M104 engine for the 240Z
  • Please log in to reply
86 replies to this topic
#21 WizardBlack
WizardBlack
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPipPip
  • 1442 posts
  • LocationMarysville, Ohio, USA
Posted 21 September 2009 - 05:45 PM
Very interesting. Keep up the good info and updates!
1977 280Z
- RB25DET swap and Q45 rear end swap in progress (Delayed!)
- Frame off resto in progress!
#22 MAG58
MAG58
    Bawb Dawg
  • Donating Members
  • PipPipPipPipPip
  • 652 posts
  • LocationBloomington, IN
Posted 21 September 2009 - 05:49 PM
What's the stroke on the 3.2 crank? Is it as heavily built as the diesel?
Yes, it's equally overbuilt, also equally forged, induction hardened at the journals and micro polished. I believe it's about an 84mm stroke. So about 8mm less.
Edit: With the 320 crank, the 280 rods, and 90mm K24 pistons, I will have a calculated CR of 8.8:1 (give or take .2), a 1.78 Rod/stroke ratio, and 3206cc's of displacement. I could spin the motor 8928rpms without hitting the 25m/s mean piston speed.
May just stash the crank away for a heavier car that needs some stroke to motivate it ;)
Datsuns n' stuff.
#23 Daeron
Daeron
    DON'T PANIC
  • Members
  • PipPipPipPipPipPipPip
  • 2129 posts
  • LocationWPB, Florida USA
Posted 22 September 2009 - 01:44 AM
You say "280 rod.." is that 280Z or MB 280??
Going on a rough swag here.. the stroke difference is about 8 mm, if you mean to say that the short stroke, L28 rod, KA24 piston combo will do you OK for piston height, then maybe the stroker crank, an L24 rod (133mm) and a VG30 piston (pin height about 31.75mm) put you near the same height for the reciprocating assemblies.
According to this utility http://www.ozdat.com...e/enginedesign/ there is a "JUN VG30DETT" piston that checks in at 89mm diameter.
Stro-Ker! Stro-Ker! Stro-Ker!
Fusible Links blow.
1-5-3-6-2-4, counter-clockwise from 9 o'clock when viewing from driver side fender
There's something about a white Nissan......
Wisdom is knowing how much you do not know.
"Indeed, if fish had fish-lore, and Wise-fish, it is probable that the business of anglers would be little hindered." -JRR Tolkien
ALL YOUR BOOST ARE BELONG TO US
#24 MAG58
MAG58
    Bawb Dawg
  • Donating Members
  • PipPipPipPipPip
  • 652 posts
Posted 22 September 2009 - 06:40 AM
No. The Mercedes Benz 280 Rods. They're 150mm (5.906in) long and a Honda K24 90mm overbore pistons with a compression height of 1.14in.
I may still stroke it, it all depends on the cost of each motor.
Datsuns n' stuff.
#25 datsun79z
datsun79z
    Butternut
  • Members
  • PipPipPip
  • 60 posts
  • LocationBeaverton, Oregon
Posted 22 September 2009 - 08:55 AM
Mag58;
I noticed the "hammer in hand". Is that a Mercedes tool of some sort?
#26 kramerbuccs24
kramerbuccs24
    Member
  • Members
  • PipPip
  • 30 posts
  • LocationAlbany NY
Posted 22 September 2009 - 12:17 PM
very interesting build, keep us posted!
1988 Toyota MR2 Supercharged FOR SALE
Looking for a 240 or 260Z to begin an RB26DETT project with
#27 MAG58
MAG58
    Bawb Dawg
  • Donating Members
  • PipPipPipPipPip
  • 652 posts
Posted 22 September 2009 - 05:49 PM
Mag58;
Heh, if it was a Mercedes Special Tool, it wouldn't be carried in hand, it would be placed in a highly guarded padded vault with temperature and humidity control as it MOST LIKELY cost more than the house it calls home.
That's my father with his favorite ball-joint extraction tool.
Datsuns n' stuff.
#28 Daeron
Daeron
    DON'T PANIC
  • Members
  • 2129 posts
Posted 22 September 2009 - 11:58 PM
okay, sooo... block height? rod big end bore/wrist pin bore/crank journal thickness? We can only Help Hybridize if you give us specs :)
Fusible Links blow.
#29 MAG58
MAG58
    Bawb Dawg
  • Donating Members
  • PipPipPipPipPip
  • 652 posts
Posted 23 September 2009 - 08:43 AM
Deck Height: 219.675mm
Origional CR (280CE) 33.275mm
Wrist Pin Dia: 22mm
Crank Journal Diameter: 48mm (same as 4G63, a bunch of hawn-ders, etc.)
Crank Journal Width (320&280): 24mm
Crank Journal Width (350SDL): 28mm
* Rod Width at wrist pin same as crank journal width
Connecting Rod Length:
280 M104: 149mm
320 M104: 144mm
Strokes:
280: 73.4mm
320: 84mm
350SDL: 92.4mm
I think that's all right...
Datsuns n' stuff.
#30 Phlebmaster
Phlebmaster
    Super Moderator
  • Members
  • PipPipPipPip
  • 495 posts
  • LocationOregon City, OR
Posted 23 September 2009 - 10:49 AM
This is looking good! :mrgreen:
Thanks, Aaron
Life is about making dreams come true, stop dreaming and make life happen. MY_YOUTUBE_VIDEOS To keep an opened mind- speculation is devine.
Assumptions always lead to a dead end!
#31 Daeron
Daeron
    DON'T PANIC
  • Members
  • 2129 posts
Posted 24 September 2009 - 02:08 AM
SR20, VG30 and VQ series apparently share the 22mm wrist pin, but nissan motors apparently seem to use crank diameters of 51 or 53 mm. I'm basing these conclusions TOTALLY on the info provided at the ozdat calculator I linked to earlier in this thread.
Incidentally, I missed the 22mm wrist pin on the VG earlier when I had suggested it be paired with an L24 rod; L-series use 21mm wrist pins.
There seems to be a VG30DETT piston at 31.75mm pin height and 89mm bore. If you can find a rod that is just a hair under 141mm long you get to zero deck height with the 94mm stroke crank. (assuming this head has a ~42cc combustion chamber and flat-top piston, this produces 3.5 liters at THIRTEEN TO ONE COMPRESSION!!!! HOOOOHOOOOO!!!)
Fusible Links blow.
#32 letitsnow
letitsnow
    Discarded Member
  • Members
  • PipPipPipPipPip
  • 872 posts
  • LocationRochester, NY
Posted 24 September 2009 - 08:32 AM
If custom pistons are in the budget, I'm pretty sure JE will make you just about anything.
'89 Firebird.......'77 280z.....'90 Firebird.....'88 300zx
#33 Evan Purple240zt
Evan Purple240zt
    Member
  • Members
  • 1598 posts
  • LocationMadison area, WI
Posted 24 September 2009 - 09:54 AM
^ So will ross.
1995 240sx....
1972 240z RIP
#34 Guest_lulu_*
Guest_lulu_*
  • Guests
Posted 01 November 2009 - 07:02 PM
Wouldnt an acura k20a connecting rod work with slight big end work, it measures 139mm , on a 48 crank journal
#35 MAG58
MAG58
    Bawb Dawg
  • Donating Members
  • PipPipPipPipPip
  • 652 posts
Posted 02 November 2009 - 12:38 PM
That would make for a R/S ratio substantially less than 1.5 which is already too short. Would make piston selection easy though piston accelerations would be through the roof and dwell at TDC and BDC would be nonexistent.
Datsuns n' stuff.
#36 JSM
JSM
    Giggigty Giggity Giggity
  • Members
  • 1430 posts
  • LocationOrlando, FL
Posted 02 November 2009 - 12:55 PM
Tranny options figured out yet?
1971 240z
1980 280zx
1988 300zxt
#37 MAG58
MAG58
    Bawb Dawg
  • Donating Members
  • PipPipPipPipPip
  • 652 posts
Posted 02 November 2009 - 01:26 PM
Yep. Mercedes CLK series 6 speed manual, 16v flywheel and spec clutch.
The 6 speed is a nice, tight Getrag unit that, iirc, is used in many a bimmer as well.
Though I'm quite sure I'm going back to the 3.2 displacement. Stock motor at 18psi netted 499rwhp @6500. That's without major computer tuning, basically a 'rough' tune which is plenty of go to hospitalize me sufficiently quickly.
Datsuns n' stuff.
#38 KillerBjt
KillerBjt
    Member
  • Members
  • PipPipPip
  • 93 posts
  • LocationBay Area, CA
Posted 16 November 2009 - 09:46 AM
NEED UPDATES! haha this thread is like crack, you just keep coming back! Love the swap and now i am thinking about maybe going down this route in the future.
#39 82boxima
82boxima
    Junior Member
  • Members
  • Pip
  • 16 posts
Posted 16 November 2009 - 01:07 PM
haha, I was just asked if my car was mercedes today, and it made me think of this thread.... how appropriate would it would it be to have one of these in a 1st gen max? :burnout:ROFL very unique swap, I love it!!
#40 PanzerAce
PanzerAce
    Used Member
  • Members
  • PipPipPipPipPip
  • 735 posts
  • LocationMerced, CA
Posted 16 November 2009 - 01:11 PM
I don't think he has any updates. Last word I got was he's (and I, for that matter) were looking for someone that'll do wild enough cams.
1973 240Z, 3.0L Rebello, "running them funny sideways triple deuces". Living and breathing again after almost a year in the shop. DEATH BY SUV, 5-16-2012 RIP.
1978 280Z Possible recipient of anything salvageable from the '73
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
