Mercedes Benz M104 engine for the 240Z
MAG58
Mag, I'll be finding out about cams and those two trans you were looking for tomorrow. Got the day off work (thank god), so I should be able to get a fair bit done.
Also, no reply from rebello yet :/
Thanks a ton PA, you've really got some good MB connections that have been a huge help in these shenanigans. :mrgreen:
What about a regrind? They can cut you almost anything.
We're working on that. I'd like to find a cam guy that kinda sorta knows his way around the motor maybe a little bit.
Spechin Deutsch?
try googling benz cams with google filters set to german domains only.... Surely there will be a german tuner crowd around over there?
Ja, Ich spreche ein bischen Deutsch, und ich habe ein paar deutsche Unternehmen untersucht.
However, the cost of the cams (the highest duration I've seen is 268 with about .385 lift) would be more than the rest of my project alone! I'm looking for some options stateside though.
Give delta cams a call, they might not have much experience with the m104(maybe they do, I don't know, just guessing), but a cam is pretty much a cam no matter what engine it's in, they all have similar design requirements(with respect to reliability). As for specs, you'd have to ask them what they can do and compare to what you want.
Hey, no problem Mag. I figure since you turned me towards these motors with that L head thread, the least I can do is tap into the knowledge base that's a 10 minute drive down the road.
The trans stuff he'll be able to help out with no sweat, less sure about the cam stuff, but he'll know where to start.
Oh, and LIS, the problem that Mag and I have found is that while there are a number of cams for this engine, they are all geared toward people with MBs...which means they won't accept something that barely idles :P
Didn't think about that problem, I just kinda figured german car guys were completely nuts and considered a 2000rpm lumpy idle acceptable.
One of these engines is the contingency plan if I nuke both of my L series, probably not for a few years.
Oh don't you worry none, they're nuts.
That said, they have big heavy cars and big heavy cars need bigger heavier engines. I'm just reaping the benfits (with my dinky little Japanese car) of the removal of very capable I6's to go to much larger capacity engines with many many more cylinders ;).
Have you tried Elgin Cams? http://www.elgincams.com
They have a Mercedes section (and Datsun!)
Copied this from their site.
No affiliation, BTW...
MERCEDES BENZ PROFILES
We have the following stock masters for regrinding Mercedes cams. If you do not see your model listed below, we can still regrind your Mercedes cams but please allow another week.
190 SL 230 S 300 E
190 D 240 D 300 SL
220 S 1958-59 250 300 TD
220 1964 250 CPE. 380 SL
220 4 CYL. 280 SE 450 SEL
220 D 280 TWIN CAM 450 SEL HYD.
230 SL 300 D 6.9 V8
PERFORMANCE CAMS AVAILABLE FOR NEARLY ALL GASOLINE MERCEDES CAMS. PLEASE CALL FOR SPECIFICS.
If the bearing journals are worn undersize on your Mercedes cam, it is still possible to save it. If the cam towers are still in good condition, we can build up your worn journals with chrome plating and then grind them back to their proper size. If your cam towers are worn oversize or are out of round, the dealer can occasionally supply underzise cam towers and we will grind down your bearing journals to fit these towers.
Update: No response from delta yet, Elgin says I should stay with the stock cam...pfft.
I contacted Colt and recieved a response from the owner less than 24 hours later. A quick phone call states that he can take and inspect the cams free of charge and provide me with available profiles that I can grind the cams to. Given the 24 lobes he believes that the cost should be in the 4-500 dollar range which is substantially cheaper than the quotes I have been getting else where and less than half what a set from the fatherland would cost me.
Goeff (the owner) is a great person to deal with and since he's never dealt with them before, he'd be doing the work on them.
Great customer service, I'm happy to say. I'll probably be shipping him some cams in a few weeks to see what the prognosis will be ;)
As I kind of expected, I can pretty much get any grind I want to on the cams, there's plenty of meat as long as I can make up for the valvetrain geometry at some point (shouldn't be an issue with direct acting cams, relative to the more complex rocker type).
That said, I want to get the car running, and see what it's capable of in completely stock configuration. I figure if my car is gonna be the performance mule, might as well see what she'll do as she left the factory at Mercedes.
After we get the thing sorted, I'll probably send my spare head to BRAAP as money and time allows and allow the good folks at Colt Cams to go nuts. Then we'll see what I can get my 0-Mother of God time down to.
Hey sorry for the late bump but I recognize that motor ;). I think you and I talked. If you want to solve your stroke problems, get C36 rods since the C36 has the same crank as a 350SD.
That's an interesting way to make a 3.2L with the first gen m104. Very cool.
Here's my 97 M104 ;)
I believe we have talked as well. The hardest part for me is finding the C36 rods not attached to the rest of the C36. Luckily here in the corn belt E85 is plentiful and cheap So I'm going to see what a smaller displacement motor can make before I dump some stroke in it. Your W210 was already quick and a Z is just a fraction of that weight.
Have you got your other motor lined up yet? I never heard if you were going M113/M119/M120 :shock: or any of the new M2xx engines.
