S30 Roll Cage Examples
  • Please log in to reply
34 replies to this topic
#21 smoorenc
smoorenc
    Member
  • Donating Members
  • PipPipPipPip
  • 188 posts
  • LocationLincolnton, NC
Posted 09 January 2010 - 11:19 AM
I had mine done by a company the requests to stay anonymous. They did a really good custom job!
Posted Image
Posted Image
280Z LS1 conversion
www.4moores.com
#22 proxlamus©
proxlamus©
    I need a hug...
  • Members
  • PipPipPipPipPipPipPip
  • 2107 posts
  • LocationAurora, Colorado
Posted 14 January 2010 - 07:40 AM
wow.. some awesome looking cages =)
Currently on a rotisserie for a full restoration - L28 with 9mm rods, 88mm Ross pistons (3.0L), 8.5:1 CR, Schneider Stage II cam, Holset HY35W, Megasquirt, Suzuki GSXR ITB's and home made intake plenum, Z32 transmission, Fidanza aluminum flywheel, ACT stage II clutch and pressure plate, coil-overs, vented 4x4 front brakes, 240sx rear brakes, Corbeau FX1 Pro seat, (soon to be half cage) and still debating the paint.. hurm
#23 hapoholi
hapoholi
    Junior Member
  • Members
  • Pip
  • 3 posts
  • Locationconroe, texas
Posted 16 February 2010 - 07:16 PM
Hey guys...the nhra style..ie.. Jegs etc. have a main hoop and also a roof hoop. The down bars meeting this roof hoop at the windshield post...Do the forward down tubes need to start at the main hoop?
#24 hoov100
hoov100
    Pedro
  • Members
  • 1531 posts
  • LocationThousand palms.
Posted 17 February 2010 - 01:09 AM
The halo needs two bars connecting the front of the halo at the top of the windshield pillars to fallow the pillar down and connected to the floor/frame.
It seems Z's and AR's should come as a package deal.
Well yeah. Thats why I need a rollcage, so I can bolt a gun rack to it.
Everybody knows WHY we have the 2nd Amendment, right? Who exactly did our forefathers see us needing protection from? Our own government.
#25 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • PipPipPipPipPipPipPipPipPipPip
  • 12413 posts
  • LocationSeattle area, WA
Posted 11 May 2010 - 03:20 PM
Just in general seems like people really want to bend tubes where they don't need to be bent. A lot of the bends in these rear supports and door bars are just not necessary. A straight tube is stiffer than a bent one. Keep it straight whenever possible (except for door bars which should protrude into the door cavity for max protection).
Where multiple tubes have to hit in the same area it's best to connect them. So to have that X and then connect the backstays to the top of the hoop doesn't make a lot of sense. Much better to either move the X so it hits the backstays, or since you already have problems with the backstays, move them to hit the top of the X if that X is legal. Not sure on that one... Connecting multiple tubes to a "node" makes the cage stronger and more rigid and allows loads to path directly from one bar to another instead of having to travel down the connection between two separate tubes that aren't connected at a node.
Jon Mortensen, owner/operator www.petdoorstore.com
#26 frank280zx
frank280zx
    HybridZ Supporter
  • Donating Members
  • 1135 posts
  • LocationAmsterdam, The Netherlands
Posted 11 May 2010 - 10:15 PM
ITs not an s30 but it is the same cage copied from an s30 (allot of tubes are the same, apart from teh front legs, the front wiendshield rake is teh same as a 911 ;)
Posted Image
I dont know if these pass tech for SCCA or NASA But i guess John can pitch in on that.
Apart from that i have seen a topic like this before with some really good examples ill lik those below.
Note that before you build your cage that for some classes they update the rules frequently. So you best off to buy the rule book or call a competent builder.
And if you really insist of welding yourself, get it checked out before putting it on the track!
For rule changes see this for example http://forums.hybrid..._1
I know builders in Europe have to proof the pentration of the material etc etc to get a cage pass. A bad weld will more likely harm you than safe you.
Now imagine a weld coming loos and a sharp piece of tube swinging at the driver!!!
If it is mainly a street car more than a hoop or a NHRA 6 point would not be advized as id will harm you more than do you good without a helmet (ever had a baseball bet swung at you by major leage player ?) the area it concentrates on is much smaller than it would be without a cage..
anyhow on the fun stuff:
http://forums.hybrid...-cage-examples/
Edited by frank280zx, 11 May 2010 - 10:17 PM.
78 ZX l28 HC ISMA widebody (FIA) vintage race toy in progres, e36 Flossmann GTR  M5 v8 In race hard use!, 49 Pontiac streamliner with Jaguar xjr v8 running gear project, 64 El camino 406 SBC T56 part hauler
#27 johnc
johnc
    Administrator
  • Administrators
  • 9739 posts
  • LocationLa Habra, CA, USA
Posted 14 June 2010 - 08:18 AM
I went through this thread and cleaned out posts that were not pertinent to the original intent of this thread. Again, this is a reference thread for good cage design to help people with their own design decisions.
----- John Coffey, Fabricator at Benton Performance, LLC
#28 leencoo12
leencoo12
    Newbie
  • Members
  • Pip
  • 1 posts
  • Locationasf
Posted 01 October 2010 - 11:23 PM
BJ Hines cage build:
http://forums.hybrid...ad.php?t=109864
Motorsci cage build with some input from a Dutch FIA cage builder (z-spec):
__________________
watch movies online
Edited by leencoo12, 01 October 2010 - 11:24 PM.
#29 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12413 posts
Posted 03 October 2010 - 12:30 PM
Link?
#30 frank280zx
frank280zx
    HybridZ Supporter
  • Donating Members
  • 1135 posts
Posted 06 October 2010 - 12:30 AM
Va-motorsport (see my cage) it was built by him aswel, Ad is a personal friend, and i can tell you they are a very competent shop.
They do allot of work for Paris Dakar and various european races.
Edited by frank280zx, 06 October 2010 - 12:36 AM.
#31 doublexl240z
doublexl240z
    Member
  • Members
  • PipPipPip
  • 82 posts
  • LocationOrlando
Posted 06 October 2010 - 02:44 PM
Frank, I don't believe the cage would pass tech in SCCA and possibly NASA. The diagonals within the main hoop don't meet criteria. I'm not saying that I believe its inferior it doesn't meet the rules.
From the SCCA GCR:
Main hoops shall incorporate a diagonal brace. The brace shall either be in the plane of the main hoop, or extend from the top of one rear brace (described in 9.4.B.2.c) to the bottom of the opposite rear brace. Automobiles with mid mounted engines can have the lower mounting point attach to the frame of the automobile within six inches of the main hoop. In the case of braces in the plane of the main hoop, the brace must span at least 50% of the width of the main hoop, and at least 75% of the height of the main hoop.
Chris Leone
11/70 Series 1
chrisleonemotorsports.com
"Crossthreading" the only thing stronger than loctite!!!
#32 frank280zx
frank280zx
    HybridZ Supporter
  • Donating Members
  • 1135 posts
Posted 07 October 2010 - 03:28 AM
Could be the just changed this in FIA aswel ( so it can pas) but that was not the point ALWAYS check your sactioning body before building ! This one is FIA compliant..
Edited by frank280zx, 07 October 2010 - 03:42 AM.
#33 wondersparrow
wondersparrow
    Member
  • Members
  • PipPipPipPip
  • 179 posts
  • LocationEdmonton, AB
Posted 02 July 2011 - 02:12 PM
I did some mods to my 20 year old roll cage yesterday (Happy Canada Day!!!) and thought I would share them. I basically cut off everything back of the main hoop and replaced it.
Posted Image
We removed the curved rear stays that went to the plate you can see on the floor, put some 3/16" plate on and around the strut towers, new rear stays, cross brace, and increased the size of the strut tower bar to match the rest of the cage. I am not a fan of the angle the belts need to go to get to the strut tower, I may think of adding a harness bar later (had to cut out the old one that was on the old rear stays).
One thing that I am actually struggling with is fastening the window net. The way it was fastened before was a little hokey. It was attached at the top, and at the bottom, old seatbelt was sewn to the net, and clipped to the other half of the seatbelt slung around the cage. There really was nothing wrong with that per se, but I didn't like having to flip the net and this seatbelt clip onto the roof to get out. The roll cage is really close to the bodywork there and every time I come up with a plan, it puts the top of the net right in my eye line and too low for comfort. A different form of clip or buckle might even do wonders. I have old harnesses around, see if those might have something that will work. If anyone is still reading this, it would be nice to see detailed pics of how yours clips in and out.
Another pic because I thought the lighting was cool.
Posted Image
Edited by wondersparrow, 02 July 2011 - 02:14 PM.
1971 240z for tearing up the track
1994 M3 Euro Spec for rockin out with the tail out
1997 Del Sol For top down cruisin
1999 Ram V10 for running down Greenpeace Protesters
#34 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12413 posts
Posted 02 July 2011 - 06:51 PM
I got a custom net and it came out pretty damn good. I posted pics of it, if you look and can't find them PM me and I'll email you some pics.
#35 wondersparrow
wondersparrow
    Member
  • Members
  • PipPipPipPip
  • 179 posts
Posted 02 July 2011 - 08:53 PM
Ah, found it Here. I was trying to do that, but I had one of the old lever style buckles, like on a plane. I was meaning to hit up the junkyard and see what else I can find. Good pics, thanks.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
