need to know the ohms of the fuel gauge
  • Administrators
Ron, is the '73 sender the same?
I've tested and researched the senders of quiet a few Datsun models. Every one, so far, has been in the same range listed above. There may be others that are different, but I haven't found one. I'll bet a buck every S30 and 510 falls in that range.
  • Administrators
Don't know if this helps... I installed a VDO gauge in my 510. Of course it would have read backwards, so I flipped the sender upside down. Simple and works pretty good. I haven't tried this on an S30, but it should work. Just bend the arm to fine tune.
