Post pics of your z's here!!
terrorizer805
I caught the bug, and ended up with a new, and much cleaner shell....
Build is coming soon, initial plans are to get it running on the L24 for a while, and then in the long run its getting either an RB or a 1jz.
Edited by Fuzzydicerule
Please Resize Images to: 1024 x 768 pixels or close, before placing on HZ.
Whao, those bimmer wheels are killer. 18's??? Off of???
Thanks guys!
The fronts are 17x8 +20 with a 2.45" adapter custom made to go from 4x114 to 5x120
Rears are 17x9 +26 with a 2.45" adapter, that was made too large, so Ill be turning it down 6mm, clear the fenders a little more, its rubs ever so slightly.
Front tires 205/40/17 that will be swapped to 205/45/17 so get some more meat
and the rears are 225/45/17 that will be going to 235/40/17 when I find a set.
Rims are style 32 bmw
peek a boo.........
So how did you manage to blend the headlight buckets so seamlessly into the front quarters? My buckets are fiberglass...did you just fill the gap with body filler? Or did you find metal headlight buckets somewhere?
