240z with RB26DETT, multilink, EPS, etc
I bought used ThinkPad X61 for ECU setting and configuring the dash logger but I couldn't make connection with logger. So I dug an old mini PC which I bought for in-car use and have been using at office until the VGA connector dislocated from the M/B. Soldering such fine pattern was quite challengeable for me but succeeded.
Display panel is 7.1" real XGA (1024 x 768). Good news is the battery voltage can directly be supplied to both PC and Display. Bad news is no room for audio. I will put some switches and I/O of PC between the display and HVAC panel. This setup enables me to type keyboard on my lap. Note PC cannot be used in such way.
Mercedes louvers cannot be there because the 240z interior is narrower. There will be round shaped louvers instead.
Making the bulkhead to isolate the fuel system.
Side panels are steel and top/front part will be aluminium.
PC display is too small for my half-century-old eyeballs. So I decided to fabricate a display enclosure to be hung anywhere I can read the small font. HVAC control will be relocated top of the center panel and an audio unit will be loaded in the lower opening.
Edited by KAZU
  • 1 month later...
Engine compartment wiring has done.
Essentially no stock loom remained. The car has only 3 filament bulbs, two H4 headlights and a battery charge lamp. New thicker Griffin Scirocco radiator.
I got a new A/F sensor of LC-1 but still no voltage. Ordered a new set. Even if with the new LC-1, I'm tired of tuning with an old DTA ecu. I'll replace it with dependable Link G4Xtreme (red) with KnockBlock.
How wide is the hub to hub measurement on that rear suspension assembly?
I didn't measure the dimension. At least two inches in each side may be added.
Update.
There was difficulty in dialing the NVCS cam timing teeth wheel because the fixing screws are put from the backside. I was planning to modify it but I found a better solution. Trust Greddy cam wheel for RB25NVCS.
