Jtr mounts
  • Please log in to reply
25 replies to this topic
#21 Eric JB
Eric JB
    Moving Up
  • Members
  • PipPip
  • 36 posts
  • LocationSkagit valley Wa
Posted 19 June 2014 - 12:03 AM
I made mine based on the JTR manual. I had to look at a pic to remember where the setback plate was. As I look at it, I dont see how it could be against the block. how would it clear the fuel pump block off?
Edited by Eric JB, 19 June 2014 - 12:08 AM.
#22 daflyinghawaiin
daflyinghawaiin
    Moving Up
  • Members
  • PipPip
  • 48 posts
  • LocationBIG ISLAND OF HAWAII
Posted 09 July 2014 - 11:31 AM
Great thread gang! I'm looking at a v8 n/a engine swap as well. Please keep these good threads rolling! BOLO
#23 adisturbedv8z
adisturbedv8z
    Newbie
  • Members
  • Pip
  • 20 posts
  • Locationcalifornia
Posted 11 July 2014 - 07:42 AM
I respectfully disagree. The JTR book basically told me nothing. There were no instructions on how to bolt up the mounts.
im not a mechanic by any means. I can do basic stuff like brakes, radiator change, small jobs etc. I bought the JTR book, bought the GM mounts it said to buy, and did what the book said to and my 350 its sitting nice and cozy in my 260z. Took a lot of trial and error, but mostly due to not hammering the transmission tunnel enough to make room for my tranny. Mounting the motor mounts to the block with the JTR stuff was one of the easiest steps i have had since i started my swap. If i were any good and electrical and made of money to buy more stuff to finish it, I would be on the road already, lol.
Good luck with your swap man.
1974 260z w/ JTR V8 Conversion Chevy 350/TH350 Edelbrock intake, Edelbrock carb, Sanderson headers
#24 adisturbedv8z
adisturbedv8z
    Newbie
  • Members
  • Pip
  • 20 posts
Posted 11 July 2014 - 07:53 AM
I dont know if this is some closely guarded government secret or what but,failure
after tirelessly searching for some info and or illustrations to EXACTLY how the JTR V8 conversion mounts are set up on the Z crossmember mounts.......I took out a 327 with fabbed mounts from JTR blueprints and it looked INCREDIBLY INCORRECT.
The setback plates were bolted directly to the block, can that be right.....?
I dont want to pay $35 to see a picture of what this is supposed to look like......
Make any sense or no..........???
Any help would be appreciated..............
I have added a pic to the origional setup.............http://i916.photobucket.com/albums/ad6/counterintel/PA220567.jpg
here are some photos of my mounts mounted right as i drop motor in. hope these help
#25 zilverbullet77
zilverbullet77
    Newbie
  • Members
  • Pip
  • 8 posts
  • LocationMelbourne, Florida
Posted 22 June 2015 - 05:40 PM
I just purchased my motor mounts, JTR plates and spacers. I am hoping to get some more current feed back(since this post is 5 years old) on which way is best to bolt them all together. Some pros and cons to motor mount to set back plate to spacer to motor vs motor mount to spacer to set back plate to motor would be appreciated. I know either way will work but I am just hoping to see what most everyone else has done.
Thanks
#26 marvo
marvo
    Junior Member
  • Members
  • Pip
  • 11 posts
  • LocationNear London England
Posted 24 August 2016 - 09:28 AM
Finally getting round to installing my SBC into my 72 240Z here in the UK using the JTR mount kit, to me the JTR manual is quite specific on which way round the mounts and spacers should go. On page 2-1 Mike states that the spacers go between the block and the set back plates, this is also backed up by the drawing on page 2-4 which asks you to remove material from the Chevy mount for bolt clearance inferring that the offending bolt is one that goes onto the set back plate newly attached to the mount, however if you put the set back plate to the block then this bolt does not interfere with mount as the large spacer takes it away from the Chevy mount.
My only concern is that there may be a good structural reason for doing it the JTR way? It seems preferable to me to put the plates to the block as this eliminates the need to cut out the section in the new mount for bolt clearance.
Any more thoughts anyone?
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
