Silver Mine Motors
Brake Kits On Sale!!!!
To help kickoff the new year we have decided to give our Hybrid Z forum members a discount on all our brake upgrades. This sale will be from today to Febuary 28th.
The new prices are as follows:
Stage 4 front kit = $445 (has not been this inexpensive since they came out)
Stage 3 front brake kit = $305 (240z kit is $345)
stage 4 rear brake kit = $755
email me for these prices edan@silverminemotors.com
Here are the pics and descriptions for each brake kit.
For more info. Go to silverminemotors.com
Stage 4 front brake kit = $445
For 240z, 260z, and 280z.
This brake kit comes with the following parts:
1. Enormous 4 piston calipers (43mm pistons)
2. Vented, slotted, and drilled CNC rotors with zinc plaiting to prevent rusting
3. DOT approved custom fabricated steel braided brake lines
4. Custom fabricated T6061 aluminum spacers
5. Ceramic brake pads
6. All the needed hardware
As you can see this kit is a complete kit. There are no other parts needed to complete the installation. Installing is very easy, and can be done in less than two hours. The 4 piston calipers you will be getting have the biggest pistons available (43mm). The vented slotted and drilled rotors are professionally built with CNC machines, and zinc plated to prevent rusting. The steel braided brake lines are custom made to fit this brake kit for easy installation. They are also government DOT approved just like the stock brake lines that come on new cars from the factory today. So you can believe they will not have any problems. The aluminum spacers are made of the highest grade of aluminum on the market T6160. These spacers are very light and extremely strong. The ceramic brake pads are built buy centric brake company. They are very quiet and smooth. If you don't want the brake pads you can subtract $20 from the final price. I personally have this brake kit on my 280z and it made a big difference, my car now stops on the dime. Pleas allow one week for parts to be built and shipped out after payment is received. Over all it’s a great brake kit that will make your Z stop faster and better than you could ever imagine. It has bigger pistons than the $800 kits Willwood sells, so you do the math. Pleas specify what type of z car you have when you order
Stage 3 kit (front) brake kit
Sale price: $345
This kit includes:
1. Four piston calipers
2. Slotted and drilled CNC rotors with zinc plaiting to prevent rusting
3. DOT approved custom fabricated steel braided brake lines.
4. Ceramic brake pads
As you can see this is a complete kit. There are no other parts needed to complete the installation. This is a big brake kit for any Datsun zcar made during 1970-1978. The calipers are four piston calipers, which are a big increase in piston size as opposed to the dual piston caliper that came on the car from the factory. The slotted and drilled rotors are professionally built with CNC machines, and zinc plated to prevent rusting. The steel braided brake lines are custom made to fit this brake kit for easy installation. They are also government DOT approved just like the stock brake lines that come on new cars from the factory today. So you can believe they will not have any problems. They are also steel braided with a layer of clear lamination to prevent expansion of the line under pressure. The ceramic brake pads are built buy centric brake company. They are very quiet and smooth. If you don't want the brake pads you can subtract $20 from the final price.
Stage 4 rear big brake kit = $755
This kit includes:
1. Pair of new 11.8 inch CNC drilled, slotted, vented, Zink plated, and machine balanced rotors.
2. Pair of brand new Enormous1.6 inch (43mm) single piston calipers with e-brake function.
5. One pair of custom fabricated 1018 alloy brackets.
6. All the needed hardware.
7. Installation instructions.
As you can see this is a complete brake kit. There are no other parts needed to complete the installation. There is currently no other brake kit with e-brake function on the market that has bigger piston calipers than this brake kit. The calipers are the strongest calipers in any rear brake kit available with e-brake for our Z cars. They feature 1.6 inch pistons (43mm) and an amazingly strong e-brake function. These calipers are also available in many local auto parts stores so replacing them is not a problem. They originally came off a car with 500 hp from the factory. So you can believe they will stop your light z car with whip lashing power! The pair of Drilled, Slotted, Vented, machine balanced, and Zink plated rotors are professionally built with precision C.N.C. machines. They are Zink plated which prevents them from rusting. The rotors are also vented which will greatly lower the chances of brake fade under extreme driving conditions. The steel braided brake lines are custom made to fit this brake kit for easy installation. They are also government DOT approved just like the stock brake lines that come on new cars from the factory today, except that they are much much stronger. So you can believe they will not have any safety problems. The custom fabricated brackets are made of 1018 steel. They will never rust or corrode. Just to give you an example of how strong they are the stock brackets off most cars today including the maxima brackets have a hardness level of about 13. These brackets have a hardness level of 17. They are not hardened on the outside, so they will not snap. The metal that was used to make these brackets is made in U.S.A. and is certified by two reputable American owned alloy companies: Nucor cold finish group, and Fry steel company. Aluminum brackets are as strong as twigs when compared to these brackets. The ceramic brake pads are built by Posi Quiet. They are very quiet and smooth. If you don't want the brake pads you can subtract $20 from the final price. I can also get you different types of pads if you email me what you?re looking for. This kit does require 15 inch rims or bigger. It will hook up right to your stock e-brake cable. Installation requires you to either: 1. Remove your stub axels. 2. Or cut of your stock drum brake backing plate. One good thing about removing your stub axels is that you get to change your old wheel bearings, which I strongly recommend you do, unless you already have. I personally have this brake kit on my car and let me tell you, I can give my unexpecting passengers whip lash when I press on my brakes. The car stops on the dime, even when I?m going well over 100 miles per hour. I use to have the maxima caliper brake kit with the 300zx rotors and it is nowhere near as strong as this kit. Note: 1. For you people who have re drilled you stub axels to a 5x4.5 lug pattern this brake kit should work for your car as well. 2. You should also think about using a bigger master cylinder when you buy this kit, the added piston area will use more brake fluid than your stock brakes. I can supply you with one for an additional $180.
hHere is a comparison of a 240sx caliper VS. our stage 4 rear brake kit caliper
Here is a comparison of a 240sx brake pads VS.our rear stage 4 brake pad.
Here is a comparison of a 240sx rear rotor VS. our stage 4 rear rotor.
Share this post
Link to post
I just wanna vouch for silverlinemotors . Great guy . I just recently put toyota 4x4 breaks in the rear and the front of my 280z turbo . Yes rear and front u didn't hear wrong . Got some of my parts from silver line came quick , looked great , and just great customer service . I recommend to all .
Keep up the good work guys/guy =).
Share this post
Link to post
I've been eying the front vented brake kit for quite some time on ebay motors and the Silvermine site. I was curious as to if you could provide non-drilled non-slotted vented rotors for the front brake kit.
Oddmanout84 yes we can provide you with blank rotors with your kit. shipping would be delayed about 4 days. send me an email at bajaracer1@yahoo.com
Did you get my email?
Just need to know where to send the money, edan@silverminemotors.com I presume?
Dave
getoffmyinternet also send me an email at bajaracer1@yahoo.com with the parts you want and your shipping address. I'll quote you for everything.
Share this post
Link to post
Hey dave thanks for the advise will do that now.
anyway shipping for both kits would be $30 a kit. so $60 total.
we accept paypal, check, and money orders.
would you like to order?
Edited by getoffmyinternet
Share this post
Link to post
this sale is back on from now until January 15th!
also i've been getting a lot of questions about drilled an slotted rotors. we can make your kit with any combination of drills or slottes for the same price. we can even write your name in your rotors if you like.
reply with your questions on this forum or email me at bajaracer1@yahoo.com
Share this post
Link to post
15 inch konig rewinds will fit over the front stage 4 kit no problem. for the rear kit you might need to shave a bit of the top of the caliper in order to get it to fit. 15 inch in diameter wheel is big enough but the top of the caliper might touch the inner face of the rim. shaving the caliper usually does the trick. if not we have had a few customers use a 1/4 inch spacer.
all our brake kits use pads that can be bought at any local auto parts store. all the calipers, rotors, and pads are oem parts off other cars.
tell me if you have any other questions.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
