I just found this thread. Hopefully the starter is still watching...
You should join our "NissanDiesel" forum if you want to find a lot of information on these engines. We are quite knowledgeable and the forum owner is *very* knowledgeable about these engines.
$1700 seems like a lot to me, but I also plan on picking up a very nice 83 maxima, spare motor and spare trans this summer for less than that, but I am lucky and have stumbled upon one hell of a deal...
Since you already have the engine and are getting ready to install it, let me say a couple things.
First, about the 5 speed tranny: when installed on diesel engines they eat mainshaft bearings. It might be worthwhile to up the size/strength of the bearing before you install the engine and tranny.
Second, about BD,SVO and WVO. BD is a great fuel and when processes *correctly* it can be a great fuel, when processed *incorrectly* it can be terribly damaging to an engine. SVO and WVO are not very good fuels. The engine will run on them, but it is hard on the already old injector pump and can cause coking of the injectors and ring lands eventually killing the motor- due to the additional chemicals found in the unprocessed VO.
Third, about turbocharging: the 280zxt ex. manifold does bolt up to the head. The thought is to use a 300zx turbo and downpipe and have a custom exhaust made. You can't run a lot of boost because you can't add fuel, but 7-8 lbs will clean up the exhaust, add a little bit of power and improve fuel efficiency to some degree. I plan on doing this once I get my car. It is more or less a bolt on mod, but you can't over boost it or you will melt the motor down. An intercooler would help, but seeing as how you can't run *too* much boost on the engine it is not really necessary.
BTW: the 240 that was coverted to LD28 turbo power is currently for sale in Denver on craigslist for $15,000.
So, welcome to the world of LD28s. I'm glad to see that someone else appreciates them as much as a select few of us do!
