- Past hour
jpndave started following A COMPLETE EARLY MODEL 240Z BODY may be available soon
- Today
IMPORTANT MESSAGE-CONCERNING NEW COMPLETE 240Z BODY ASSEMBLIES FOR SALE I just posted information concerning new complete early model 240z bodies assemblies that may be available in the near future. It is posted on the BODY KITS AND PAINT SECTION of Hyprid Z Forums on Monday. There are a lot of pics and text discussing their construction and quality. Information about the manufacturer is also listed. There was a lot of interest in their line of reproduction vehicles( Toyota Land Cruisers,Toyota A86, Ford Bronco bodies). Also, I also post text and pics of ALL ALUMINUM BODY PANELS FOR 240Z MANUFACTURED IN JAPAN. Weigh savings are about 20 to 30 percent and very corrosion resistant. The workmanship was excellent and looked beautiful. This is a limited production run so if you are interested, I would put your order in. Star Road in Japan is handling the sales of this product. I will also start posting pics and text of other cars and products that I found at the SEMA SHOW 2025. This will posted in my usual Hybridz Forum site at V8 ZForums-Gen III & IV Chevy V8z site soon. - Yesterday
I had a couple hours this morning, so I went ahead and worked some more on the layout for my brake master cylinder backing plate, and then installed my brake "parts", that divert fluid to all 4 wheels (I don't know what to call them). I used Finishing Lines for the hoses. These hoses are the new PFTE hoses that do not swell, etc. Guys are completely running brake lines in whole cars with these and they work great! I will be doing a combo of hard lines and this. Everything past the firewall back is the stock stuff. www.finishing-lines.com. They advertise a lot of Honda stuff, but they DO have our 10mm fittings etc. Great people to work with. I then went ahead and pulled the back window as part of gutting the rusty hatch out and then installing my new hatch I got form Resurrected Classics. My hood is at the sandblasters right now, should pick it up tomorrow, and then I can cut the hole and repair the spear with all metal filler a tad, as I can see some mud in it. Seriously thinking about having the hood and the deck lid powder coated gloss black to contrast the light blue metallic. Black spoiler and air dam also (they are already black, I can put a coat or two of 2K clear on them), I have glossy black flares........I will attach a pic that a guy did this with..... but the car is red.....it is giving me these ideas. Pics follow, Cheers!
just barely screwed them on and took a pic.
Good list, I went with the track Attack kit And a 370Z diff (R200). I went with the Bull Dog Frame rails as they can go over the existing frame rails. They are still in the box though, I’ll install those after I install the rear suspension. -
Those struts look really long. How much can they be shortened and still maintain sufficient travel?
When I installed my small block Ford in my car there wasn't a kit available to mount the engine and transmission. So, like you, I had to figure it out on my own. A particular challenge with these cars is that they are small and you will end up with a very short drive shaft. Because of that we have to pay particularly close attention to driveshaft angles. We need the axis of the engine to be parallel to the pinion axis, and to keep the u-joint angles as low as possible. If you don't do these things you will have drive line vibration that will make the car very unpleasant to drive at high speed.
Mitchel0407 replied to FastFloridian's topic in S30 Series - 240z, 260z, 280z
What did you get, the Pro Touring kit? I do like how the Apex suspension looks and I heard a lot of good things about them. I also picked up some parts for myself to try out. Modified S30 Z’s are rare in Europe and once with anything more the coilovers even more so I’ve never seen the Apex suspension myself. I will eventually move down the new Retro Mod line as I want to keep the stock drivetrain and R200 diff but for now I just got some nice upgrades that give me the adjustability I need. - Front fender brace - Frame rails - Rear strut brace - Front control arms - Steering knuckles - Front crossmember - Upper steering rack clamps - Rear control arms -
Today my fiberglass smooth cowl I bought from Jhousa Ramos arrived and I got my caliper / lower strut assemblies back from welding. The cowl is really a nice clean part. JP Fiber Shop – The world of your car
- Last week
Thanks. I ordered a can, I’ll see where I can squeeze some in. Also Apex rear suspension got here today, going to get to started on that this weekend. 🤗 -
It is as firm as a rock.
How many of you have played around with Crossmember plates/shims, hammering a trans tunnel in a bit, engine height, trans height and driveshaft angle? I am now stepping into this new realm. I have my Vortec 4200 in, now for the trans. If you plate the crossmember you give up ground clearance, and the more you plate the more fender wheel well gap you will have, so you raise one, then adjust the coilovers to take it out, but coilovers only have so much adjustment......using aluminum plates, I can get it to where I may have to actually take the plates in to a machine shop to mill them to a precise measurement. I have some megan racing coilovers being welded on to my spindles right now. Not interested in messing with the motor mounts and like my engine riding high, so I guess we shall see!
Yeah, getting rid of that crappy worthless "undercoating" is very satisfying and worthwhile....as well as all that 50-year old dirt, gravel, and grease! Looking good! P.S. While you've got it stripped down, this is a great product for protecting your frame rails and other hard-to-reach areas on the chassis: https://www.eastwood.com/eastwood-internal-frame-coating-14oz-aerosol.html -
Hydraulic Clutch Pedal Modifications- I enlarged the Clutch Master to Shift to move about 1" to the Left. Interior Side of Clutch Master Mounting Bracket checking Push Rod Clearance Measuring Master Cylinder Piston Depth then adjusting Booster Clearance to 3MM. Modified Clutch Pedal by moving the Clutch Pedal Push Rod over about 3/4" to the Left. This small movement of the Clutch Push Rod Pin Mounting Bracket should allow even Larger Clutch Master, in case of Installation of a Larger Clutch Assembly. Finished Installation Next-ROAD TEST -
Did you grab the engine and see if it moves? That's all I was suggesting. Trust (your ideas). But verify (that they work). “Give me a lever long enough and a fulcrum on which to place it, and I shall move the world. ” ― Archimedes
it is the angle of the pic. Look at the one right above this. It is clear of any obstruction.
well, the factory motor mount for the L series six is a solid design with a rubber pad on the bottom. I have poly bushings where the engine mounts attach to the arms coming from the crossmember. The arms are made of 3/16" steel, very thick and heavy and professionally welded. In short they won't break, and they won't bend. Twisting forces, I guess that could be an issue down the road, but if it is present, then regardless of what style is used it would be present. the style used is one that is currently used by a ton of guys running LS powered cars. If you can grab this engine at the top and pull on it, and bend those 3/16" steel plates you have balls of cast iron. In fact I would be seriously willing to wager $1,000 that you could not do so. You could take these out, put one of them on its side and stand on it and it wouldn't bend. I will allow that something could go wrong.....I'll address it when it does. I appreciate the points to ponder though. Cheers.
It's hard to tell from the pictures, but it looks like you could lower the engine quite a bit if you used a remote oil filter.
After many nights thinking about it, the current Black Friday sale and optimizing my order for the most value for my money I finally decided to pull the trigger. Maybe it’s because of the size and weight of the total order but the calculation of the shipping was a bit weird. As the parts will need to be shipped to the Netherlands I knew the shipping would be expensive but my shipping came down to almost $600!! By combining some stuff I got the shipping to drop down to $280,- while still giving me the stuff I wanted and basically a free rear strut brace. Here is a list of all the stuff I got: - Front fender brace - Frame rails - Rear strut brace - Front control arms - Steering knuckles - Front crossmember - Upper steering rack clamps - Rear control arms While weighting my options Apex dropped there Retro Mod line of suspension which allows you to keep the stock R180 or R200 long nose differential, axles and spindles. I really wanted to get the new rear suspension and subframe but found it to be too expensive for me at this time. By dropping the rear subframe I got to order the front crossmember, control arms and steering knuckle and still be a lot cheaper off. Weirdly ordering all the front suspension bits separately was almost $300,- cheaper than buying the Retro Mod front suspension kit. Seeing as I don’t need the tie rods (and the steering rack, you need to buy that separately) I’m even cheaper off. I’m hoping to get the frame rails and fender brace fitted over the winter and have the car ready before next spring.
I don't know how you have the engine placed, but I would offset the engine about 1 inch toward the passenger side. The drive shaft angle is easier to minimize with the engine shifted in-line with the pinion. This also makes the weight distribution a little better when you are in the car.
My god, seeing that engine finally inside the car truly gives some perspective just how massive that engine is. The L series looks small in comparison!
SEMA SHOW-Complete Early Model 240z and All Aluminum Body Panel 240z This After Show will give you details about the latest news of Early Model 240z Body Panels. The First will a Complete Assembled Sheet Metal 240Z manufactured in China. Jiansu Juncheng Vehicle Industry Company makes Toyota La Madzand Cruiser 40,60 and 70 series,Land Rover 90/110 series, Ford Bronco1966-1977 Nissan 70-74 240Z, Volswagen T1, MadzaRX-3,and ToyotaAE86. Individual Body Parts(Doors, Hood, Fenders, Grilles,etc besides complete Body Assemblies. 240z Engine Compartment Pic 240z Front Wheel Well 240Z Right Inside Door × 240Z Interior Compartment Toyota A86 Interior Compartment These pics taken of their brochures. This is a page from their catalog. It shows the individual 240Z Body parts which are available. My opinion is they should try to sell the body parts that other than what is presently available. Parts like inner body panels, whole floor pans, inner fuel compartment, etc should be sold. Parts that are commonly needed to fix corrosion prone areas. After all, they already made the panel molds. Also, I have another comment about their body parts. Their Firewall does not have a Vehicle identification Number stamped on it. Without a manufacturer identification number, vehicle registration maybe difficult in most states Their Price List shows the Full Assembled 240Z costs $1500 arrived at Port of Los Angeles. Let me tell you my Automotive Background -I was a ASE Certified Automotive Mechanic and also ASE Certified Automotive Collision Repairman and Painter before I give you my opinion about these Chinese Body Parts. I gave this 240Z a good inspection and asked a lot of questions concerning the manufacturing of these parts. Their Sales Team was not very informed about the actual process of manufacturing of the body parts. So I had to go with what I could see and feel for this opinion. The parts seen to fit together ok but without a Frame Measuring Gauge( Tram Gauge I could not determine the Frame Squareness and Length. The biggest problem with these parts is their Corrosion Control Methods were lacking. They should be at least be coated Epoxy Primer before welding the car together. Nissan factory cars are completely immersed in tank of primer. This method insures primer covers even boxed sections of the vehicle. This a pic of the Storage Compartment behind both seats in the car. No Primer-Corrosion already on surface Maybe the Manufacturer was rushing to get the 240z into the Sema Show or maybe this is normal. This company was still looking for someone to distribute their parts in North America so we have wait and see. For more information- email this address Next-All Aluminum Panel 240Z manufactured in Japan -
Hey everyone, I'm in the middle of rebuilding the L28 in my '81 280zx 2+2 and I've hit a brick wall. I'm trying to get the oil pan and the lower engine block/upper pan (the big cast aluminum piece) off, and it will not budge. I'm 100% sure I've removed all the bolts I can see, but it's sealed on there like it's welded. Here's what I've tried so far: Engine Oil Pan Separator Tool: Did a bit but not a lot. Razor Blade: I'm trying to work a razor in, but it's taking forever and barely making progress. I'm worried I'll be here for days. WD-40 : Thought that i could break up the seal/glue with it and... nothing Tap the side of the pan with a mallet to shock the seal; nothing I'm getting frustrated and don't want to start prying and gouge the mating surfaces. Am I missing something obvious? Are there hidden boltsthat I'm not seeing? What's the magic trick to breaking the seal on this RTV from hell? Any tips, tricks, or tools you've used for this specific job would be a huge help. Thanks!
I'm sure that you've considered it and I don't know what you would do to cure it if it is a problem but those engine mounts are very long lever arms. What happens if you grab the top of the engine and pull it side to side? Probably best to test it now than to wait. Even the mass of the engine in a turn will place a lot of force on them. Just something that grabs the eye from the pictures. Unusual engine mounting. Edit - fore and aft also. Much lifting force on the rear mount under braking. Fatiguing of the front crossmember engine mounting points might be a problem. It wasn't designed for that type of twisting force. And you've moved the elastic portion up to the engine at the top of the lever arm. The attachment to the crossmember is all metal. Hate to be a Debby Downer but you have access now to work on it, rather than later.
11-08-2025. VERY busy day. running around trying to finish all the little things keeping me from being able to drop the 4.2 into the Z. Then I dropped it in. Feels great to have gotten it done, at least this far. I also was able to do some old paint removal.....the paint on this car is SO THICK.........anyway, pics.
Who's Online 2 Members, 0 Anonymous, 875 Guests (See full list)
