alainburon
  • Days Won
    3
Everything posted by alainburon
  1. Thanks Dave, I appreciate it sir. Thank you, it will hold 19 1/5 gallons. Thanks, I learned a lot during this build and I'm not as good as a lot of guys here that are true fabricators.
  2. The main thing I wanted to accomplish was for the fuel tank not to hang down below the rear valance as well as the tank not being inside the car like most fuel cells since this is not a race car. I was able to finish installing the fuel tank this weekend, I had a 2 inch inlet tube made for it in order to use the factory fuel filler neck. Made the braided lines and tested them under 500 psi of pressure for leaks. The tank has an AN10 outlet which steps down to a AN8 at the fuel filter. It has an AN6 for the return from the fuel rail and an AN8 for the vent. It's a shame all the work we put in for something that will never be seen....LOL
  3. Amazing how good that car looks after all these years.
  4. Thank you for all the kind words, I really appreciate it. My inspiration for this build has come from this website. There are a lot of awesome builds here. Yes sir I used the JCI engine mounts. As for the headers I got the ones from 417 Motorsports. They were the 1st to make long tube headers for the S30 LS swap and had a group buy in this site. The problem I had was the O2 bung on the driver's side header was in the wrong clock position and the O2 sensor would hit the transmission. Also the bolt that holds the steering shaft to the knuckle close to the fire wall was hitting on the primaries. I used small spacers between the driver's side motor mount and the engine block to move the header away from the steering shaft and used a bolt with a much smaller head on the steering shaft. Thank god that solved the problem. I did have to send the header to be re-ceramic coated once I had the bung relocated to the right clock position. Not major problems but time consuming and frustrating. I always keep saying "if it's not one thing it's the next" but in all honesty it will be all worth it when I get the car on the road as there won't be another one just like it. Especially since most swaps are going turbo now.
  5. Thank you, they are Milspec connectors. Real easy to engage and disengage. The pictures are from the engine bay side right under the battery tray.
  6. Thanks Jim, I appreciate that sir. I would not passed on it either. Looks like good quality parts.
  7. Moving along at a turtle's pace but moving along. Got a new job and I'm doing quite a bit of traveling therefore the car will not get worked on as much as I would like. I was able to finally get the plate I had made for the Mislpec wiring harness bolted in place and the harness fitted. The plate fits under the battery tray at the firewall and it's not visible from the engine bay. Used a rubber gasket between the plate an firewall in order to ensure water does not come in to the cabin. Working on the fuel tank next.
  8. I bolted my T56 Magnum behind an LS3, I removed the factory trans mounting ears from the trans tunnel since the aftermarket mount I purchased did not use the factory mounting. The T56 Magnum I used was modified to fit an F-Body Camaro, the shifter came out in the center of the factory hole. The stock T56 Magnum shifter point is too far forward. You can purchased the F-Body modified T56 Magnum from Tick Performance. That's where I got mine.
  9. Thanks trackspeed, I'm back on it just needed a break as I was getting frustrated. It seemed like nothing would fit as it should. Finally had the last modifications done to the fuel tank and decided to polish it some. Not mirror finish since I like the stainless pattern to show through. I should have it installed this weekend once I make the fuel lines for it.
  10. I have a T56 Magnum and did not have to modify anything on the trans tunnel. Mine is a 78 280.
  11. After a 2 month break from working on the car I'm back on it, I was so frustrated with the car that if I did not stop working on it I was going to put a hammer through the windshield. I would like to have it ready for some upcoming events around here so I decided it was time to get back to work. The wiring fun continues, I will fit the rest of the mil-spec engine and Nitrous controllers harness this weekend and continue wiring the chassis harness.
  12. I know the feeling man, mine was the same way except my doors were good and I was able to find a pair of brand new OEM fenders. You would be better off buying a good hatch for it than spending a bunch of labor on fixing that one. Ask me how I know.....LOL.
  13. I have not made much progress due to all the business travel but finally got the mil-spec wiring harness fit on the engine. I'm very happy with the results, definitely not as bulky as the harness I had before, just a much cleaner look and every single wire is labeled. The large connector is for the engine and the small connector is for the Nitrous controllers. I wanted to keep it all separate just in case I decide to eliminate the Nitrous in the future my engine harness remains intact. I'm now working on making a plate with a rubber gasket that I can fit on the firewall for the mil-spec plugs to mount to.
  14. Thanks for the kind words. I appreciate it. Westside Upholstery did my interior. 713-932-6501. Good to hear you like the OsGiken, I hear a lot of good things about it. Can't wait to test it out myself.
  15. This what I did with mine, I used the factory mounting holes because I did not want to drill any more holes in the firewall.. I just made a steel plate and drilled it to fit the pedal and the original mounting holes. It's very sturdy and I think it does not look bad. I'm not sure what car the pedal fits but I took a close up picture of the part number in case this works for you.
  16. I'm still working on the wiring, just taking my time to make sure everything works as it should. I decided to replace as many of the switches I could find new. That's has been a major undertaking since it seems like there are a lot of differences between S30's depending on the year. I was able to find them though, it is crazy what some people are asking for NOS parts for these cars. I just can't leave 38 year old electrical parts and expect not to have problems later.
  17. Holy crap man, that car is going to look like a space ship. Just be careful when flying....
  18. Thanks Jim, there is nothing average about your build sir. In fact most builds on this site have their owners touch that makes them unique. I have been inspired to do mine by looking at a lot of builds on this site including yours. Thank you all for the great work and all the kind comments that has inspired me to continue building my car even where there were times when I wanted to throw it off a cliff... lol
  19. Keith, Wizard Cooling can build you anything you want for your car.
  20. Awesome, can't wait to see it when it's done. I had a guy come from Dallas to take a look at my car and wanted to trade me his Alpa12 GTR straight up for my 280. I have to be honest, I considered it. He had time slips of 8.3 in the 1/4 and some videos to back up his claims.
