23
Posts posted by RB26powered74zcar
Try posting good clear pics showing both inside and out. That always works to help get a fair market price.
Which L series is in it?
Mmm.... ok. So will you be selling it? I like it. Let me know if so.
Which ones? Stock? Sectioned tubes? Early / late 260
Please provide more info on your Z
How about these? The on-car picture looks the same but the detail doesn't look tapered. Maybe it's just the angle of the photo?
Thank you for the response ! I will look into them
Nice smooth and fast run....
I wish I still lived in SoCal, where they have everything one might be looking for (speed shops etc.) I think I'd have my brackets yellow zinc dipped, instead of powdercoated....
When you live where I am, there are no good places like that locally ...
Please see this new thread http://forums.hybridz.org/topic/127169-mfactory-r200-helical-lsd/
Received my box today. All looks well. It will be awhile until I install. I'd like to thank you again for your effort put forth to make this happen !
joel
Gents...
I too fitted my kit this week (I still had the prototype kit fitted !). As you know, I sandblasted, then painted mine brackets. When i was fitting them, I had done everything and was at the stage of bolting the calipers up to the bracket. I was surprised when the 2 bolts for the main caliper got VERY tight, and to the point where they would tighten no more without extra leverage.. So..I removed the rotor, and ran a tap through the holes....it was the paint !.....i have never experienced this before, and after i ran the tap through, the bolts went in as they should !.
So.....this is just a heads-up for all you guys getting your brackets powder coated (or even painted) ....make sure you at least try threading your bolts all the way through EACH hole BEFORE you fit the brackets up. Its a little awkward re-tapping them once the bracket is bolted up !
Cheers
Thanks for the heads up Warren!. I will be sure to check mine out before install...
Joel...
Yep..pads come with the Mc4's!
Love the red...wish all mine were red lol
The red does look nice. I'm glad they have the black though, as all my wilwood calipers are indeed blk.
http://www.ebay.com/itm/400786368374?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Very nice!
Do the pads come with the new WILWOOD MC4 MECHANICAL PARKING BRAKE CALIPERS?
I'm looking to pic up a pair here > http://www.ebay.com/itm/271443710658?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Absolutely one of the sweetest done up 240z's!!! My only change would be a LS / T56.
Any one know source? Whitehead Performance has had my 300ZX Turbo driveshaft for 6 months. Repeated attempts to get status have failed. Take care, beware.
Sorry, this makes no sense to me.....
You need to be a donating member to post parts for sale.
You can donate to the site from the tab above.
ritrebor
You are correct.
Sent my balance etc. via PayPal
Thanks
~joel
I worked with laminated glass, plate glass / mirror and plastics for 30yrs until I became a disabled Vet. My experience tought me how to stop a 'run' in glass and lexan / plexi glass by drilling a tiny hole at the very end of the 'run', crack, so that when it continues to run, it will have to stop at the tiny drilled hole. Use the smallest drill bit you can find.
If you'd rather not test yourself by drilling a hole, you can hope it does not "run" any farther by just barely tightening that fastener where it's cracked putting least amount of pressure on that area.
EDIT:
Sorry for repeating what you said above Svt40.
I'd like to get mine powder coated instead of painted. Can you send mine raw?
Thanks
~joel
Second pic shows some metal being, maybe hammered out in the wheel well. Last pic shows slight front end damage from a wreck. If that's the worst of the damage, it looks repairable....
It would be very helpful for you to acquire a Service Manual. It should show all the harness routing.
Sorry, that's all I can offer for help...
Speedometer
in Interior
Posted
Cable only. Are you sure it was screwed into the gauge completely , as to engage the dial mechanism ?
