malibud
Content Type
Profiles
Blogs
Store
Posts posted by malibud
I have one but someone took the head off cylinders look good long block 81 distributor no turbo or manifold $500
I am removing a 75' tanks to replace it with a 72 tank . I found out the fill next from the 75 will not work . Can i use the straps from the 75? or do i need to find straps from a 240?
going with a intank fuel pump
Will fit 70-73 for efi really good shape inside and out it has been taped off sitting in dry storage
dc1298@hotmail.com
well bleeding it is tough I had to take the master off an lay it low . I used a willwood master as well
Does it clear the cooling mod ?
yes I am not on here all the time so easier just to email me .. dc1298@hotmail.com
How much for the turbo distributor? dc1298@hotmail.com
Yes so if it was a rod knock wouldn't it keep knocking if the plug wire was pulled ? The rod is still moving ? Also mine was much louder . my engine sat for 30 years ran great for a couple thousand miles before the sludge broke loose and clogged the pick up tube
Sure brake calipers pads are good unknown miles I think the lines are still attached. for use with stock rotors
dc1298@hotmail.com is best I will take some picks later
so i have a set that are sitting in an r200 right now they are 280Z correct ?
I think I do how can you tell the difference between 280 and 240 would like to sell as a pair
Block has been sold everything else still available
Complete 240z suspension with Tokico illuminas adjustable shocks $350 local pick up
14" Konig rewind black with Chrome lip $300 with 1/2 tread Michelin tires local pick up with tires (maybe could ship without tires?
toyota brake set up for stock rotors with pads and lines 100$
N42 block O ringed, with VO7 Crank in it. Has 5 turbo pistons forged and 240z rods, No I don't know what happened to the 6th rod and piston ... $1300
New set of Ross racing turbo pistons I will get back on size no rings but has the pins $550
Saw blade 15" rims $100 local pick up (may could ship)
Panasport 16" chrome rims good shape. positive offset (Tires rub a bit 16/60/215) should be fine on a 280zx this is what they were on originally or lower profile I can measure the offeset $700
Rebuilt stock turbo I have paper work for rebuld and new improved impeller (cost $1100) your price $500
240z intercooler may work on others custom set up goes around the back of the engine $400 (lots of $$ went into it 2" maybe too small for my goals)
Ported E31 head Lots of money spent on the head. Shaved .080 . Cam tower shimmed . Hand ported by a very expensive guy who knows Datsun. Std exhaust valves. Oversized intakes. Probably 500 miles on it . Made great power on dyno. 235ho to rear wheels at 7000 rpm
11:30 compression with flat tops. Electromotive cam. .525 lift 280 dur. Rare Asymmetric cam. Ready to bolt on and just adjust the lash. $1400Prices do not include shipping prefer local pick up
280zx trans 1982 used $400
I will post pictures later for anyone who wants or can answer questions fastest response is to directly email me at dc1298@hotmail.com
I do have other parts as well
Where in NC are you ? I am in asheville
Thanks New Zed I just sent him an email
sorry should have specified r 200
Is anyone making or has one of the Braces for finned Differential cover to use in a 240z?
thanks
DC
pm sent
no just N/A
i will look but i think i have both
488 lift turbo cam. about 2500 miles. Vrl reg. with the additive for break-in. Vr-1 synthetic. Cam looks good so far. Haven't removed any rockers yet Delta did the grind on the rockers
Drooling...
3 way oil catch can question
in Miscellaneous Tech
Posted
I had mine valve cover to intake before turbo pcv and block to catch can
