240z dash in a 280z
Hello,
Im sorry if this has been asked before but I couldnt find an answer.
will a 240z dash fit in a 77 280z? Also will the center console fit? there are some great deals on 240 interior in my area right now and I have been trying to bring my own tattered dash back from the dead to no avail. Any help would be greatly appreciated!
marcus
p.s.
Got my build thread coming up soon!
I looked at both the links and niether one realy answers the guys question , yes they swap no they dont swap , bolts right up easy and wont bolt up requires extensive modification .
I am currently repairing my 240 dash and swaping in a 280 tach before I install it in my 280 chassis so I will try to post details on what needs to be done.
Make It Work !
Edited by Robzzzz
Which version of the 240Z do you have? Early or late? The 280Z dash should install fine in a later 240Z, the early has a couple extra brackets to remove and you may have to drill a little. The size as you can see is basically the same, it's the mounts that will need attention.
