WTB: 76-78 280z R200 Companion Flange/Pinion Flange/Yoke
Akira
You should do some research. I remember reading one year is different than the rest. GLW your search
Thanks, I've done my homework. The 75 280z which I have has the different flange from the other 280z's. I have a new transmission and driveshaft which requires the r200 companion flange from the 76-78 280z.
  • 2 years later...
Bringing this back. Looking for another one.
WTB: 76-78 280z R200 Companion Flange/Pinion Flange/Yoke.
It's the flange part on the R200 that mates to the driveshaft.
Thanks!
I have several of that flange you are looking for. Send me a PM.
I came across this thread and I figured instead of start another, I'll throw in that I'm looking for one of these as well. I'm looking for second/middle pinion flange in the above pic to mate the diff to the driveshaft in my 76'
The one in the middle looks like the one that I have on a 3.54 diff from a 81zxt. I plan on removing it this weekend from the diff. I'll verify dimensions again. Can you verify that your 76 driveshaft uses 10mm bolts and not 8mm?
Edited by Akira
