speedometer and rpm guage stopped working
Yes and no. Its probably a blown fuse but possible that its a loose ground. Go through. Your fuse box check all fuses. And clean all contact Points with contact Cleaner. If that dosent help start checking for loose or damaged wires. Also inspect your blinkers while your at it they could possibly be shorting out.
Since you have an S30 which has a mechanical cable driven speedometer, I can't imagine how it quit and be related to the tach which also quit unless you have an aftermarket electrically driven speedo in there. If thats the case, then the wiring for it is all custom and you'll have to dig in to that wiring to solve the problem. Its been a week, made any progress?
