wiring harness 6.0L gm
Psi, various eBay sellers. Mine is from donor car modified and flashed by lane Colvart in Huntsville Alabama for $250.. Fired on second turn of key. I had to add fan relays fuel pump relay and fuse block. Some harness builders include those parts. You will need them. I bet I have $500 in wiring so if you get a complete harness with fuse lock & relays for that you are doing great.
AeroZ got his from PSI and it even came with an instruction book. I saw his install and it was really neat and clean with the PCM under the dash on the passenger side. He loaned me his instruction book and it was really helpful for me, even though I didn't use their harness. When you get to the wiring point, you can PM or call me and I'll help you. It isn't that hard, but it is intimidating. Until you are holding the harness in your hands and have the motor installed, none of the terms and descriptions have any meaning. You just gotta go for it and follow thru and not give up. Whatever you buy, it won't be right and you will have to customize it to your configuration.
