installing an obx lsd unit
280z4me2
Got my rear end dropped and have an OBX unit I will be dropping in in place of the stock open diff in my r200.
Do you guys normally follow the steps on checking and adjusting backlash or do you just bolt it in with the same shims?
Also, easiest way to check gear ratios in two different r200 sitting on the work bench?
