L28et ignitor alternatives
subtle_driver
Hi, I'm in the process of installing an l28et from A 83 280zxt. I have the ecu harness but discovered I'm missing the ignitor. They go for $120-$200 and I was wondering if there was a cheaper alternative I could use. Possibly from a 240sx, or a gm or ford that I can grab from the parts store. Thanks :-)
The Ignitor is an amplifier.  It takes the signal from the ECU and amplifies it to state that will fire the coil.  Simple as that.  And yes, the GM HEI works as a substitute, it's easy to find, and cheap to purchase.  There are several threads on how to hook them up - they have 4 spades: power, ground, signal from ECU, signal out to coil...
