Another VG30et swap
Well it's been a while. I couldn't work on my z for over a month but now I'm finally back at it.
No major updates, just started to organize and clean up engine bay.
Tested WG actuator, which is a stock z31 actuator modified to fit, for some reason it starts to open at 10psi and fully opens at 14.
I guess the spring was damaged by heat when we welded the rod.
Edited by rus
  • 4 months later...
Since stock crossover pipe was right next to stock 280z brake lines I had to reroute them.
Bought a roll of brake line and rerouted all of the brake lines in the engine bay, including clutch line.
Put the brake booster and downpipe back on only to realize that downpipe is touching the brake booster...
I guess the brake booster I got at the junkyard is either slightly larger or shaped differently than the stock brake booster.
