Question about coil over sleeves.
Hmm, haven't heard of serial 9. If it is indeed 2inch ID you might be able to get it to work pending the height of the tube and thread pitch.
I guess that came out pretty blunt.
Allow me to elaborate... So your choices are serial 9, mikinney, and zccjdm or I guess home made. Mikinney only sells the 280z version (2 and 1/8th) according to their website (might be able to ask if they have any of the 2 ID size left), and serial 9 adapter is for a mx73 cressida, so the only ones that are specifically made for a 240z and I believe have the little hump carved out to seat right up against the bottom of the housing is zccjdm.
If you have the 280z sleeves, you can use 280z suspension. Pretty much interchangeable and it will have the stronger stub axle to boot. The extra length and height don't matter all that much since you will be chopping it all off anyways.
