Ground Control Coilover sleeve length
yap.
I ask GC to exchange 12" spring to 10" spring since I read this.
forums.hybridz.org/topic/85673-ground-control-coilover-installation-instructions/
My plan is using 4" sleeve with 10" springs 250lbs/275lbs.
Weld the ring 5.25" front, 8.25" rear.
However, once I use camber plate, the measurement will be changed.
I try to figure out how much strut tube I should cut off for both case using original strut insulator and Techno Toy camber plate.
  • 2 months later...
Aug76/280 - sectioned struts - 8710 Konis - Ground Control CoilOvers - Trevor? - Question about front strut assembly; the literature included shows the GC aluminum upper spring seat installed against stock upper mount (without bearing) when bearing is installed, the aluminum spring seat binds against the rubber on the upper mount (preventing rotation). What am I doing wrong? Is a spacer required between bearing and upper mount? Modify mount? Any comments / assistance will be appreciated.
